i put new main relay on my 1990 accord and still no starting???please help
Old Jan 18, 2009 | 10:43 AM
chad olson's Avatar
Default i put new main relay on my 1990 accord and still no starting???please help
i bought a new main relay for my 1990 honda accord and the car still won't won't start so i checked if it getting spark and no spark????wats next!!!!!someone please help??? i been at this for weeks and can not figer it out??
Old Jan 18, 2009 | 11:03 AM
redbull-1's Avatar
Default Re: i put new main relay on my 1990 accord and still no starting???please help
Check this link out for troubleshooting:
http://techauto.awardspace.com/ignition.html
Old Jan 20, 2009 | 10:59 PM
accordn2o's Avatar
I had same problem. change ignition coil in distributor. fired first crank after i put it in.
Old Jan 21, 2009 | 10:10 AM
1slow02's Avatar
I am having some similar issues with my 94 EX. One day my car just cranked and cranked after being in the sun, and I found out the problem was the main relay (thanks HT!!) Now even after soldering the weak joints, the car wont start!! I turn the key, and it doesnt do ANYTHING!! Sometimes it does this for a second or so, then starts up. Sometimes it just doesn't do anything until it wants to!! Any ideas on what my issue might be? This is making me want to get rid of my car
Old Jan 21, 2009 | 12:36 PM
dennis's Avatar
Is your fuel pump priming when you turn it to the "on" position? What's your CEL (check engine light) doing?
I'm having a similar issue in a 96 EX which I originally thought was the main relay, but I've since changed it and it still occurs from time to time. When mine (my girlfriend's) isn't starting, it's not priming the fuel pump. I'm just wondering if something else is failing and keeping the ECU from sending the ground signal to the relay - which would prime the fuel pump. I'll hopefully run more tests this weekend, but it's hard to diagnose when it's working...
Old Jan 21, 2009 | 09:02 PM
accordn2o's Avatar
try replacing the ignition coil in the distributor and buy a new main relay. you probably messed it up trying to solder it.
Old Jan 21, 2009 | 09:03 PM
TheMuffinMan's Avatar
He knows where you live!
Electrical portion of ignition switch might be the culprit
Old Jan 22, 2009 | 09:01 AM
Blackcb7's Avatar
I had the same problem changed the distributor.Ignition coil.igniter.main relay checked to see if the fuel pump is working it is. I did all the things listed to find out that i snaped my crank shaft...So i say you check that. Does the car crank over?? NO spark or anythig??
Old Jan 22, 2009 | 09:02 AM
Blackcb7's Avatar
Now im swapping an f23 out of a 98 acura cl. :-)
Old Jan 22, 2009 | 02:27 PM
chad olson's Avatar
i wake up this morning and tried for the final time and it didn't start??it cranks but doesn't start??? so i checked for fuel and spark and its getting both??so i swaped a different ignition module and the car started right up!!!but the problem iam having now is that the car won't rev past 3,000rpm???????
Old Jan 22, 2009 | 02:31 PM
chad olson's Avatar
and another problem i having is the check engine stays on all the time?it doesn't flash
Old Jan 22, 2009 | 02:56 PM
Targa250R's Avatar
be professional
The '90 Accord has a red light on the ECU that flashes stored codes. It can be read through a small window in the ECU mounting plate and ECU case. Peel up the carpet in the passenger footwell and check the codes with the ignition turned on.
Old Jan 22, 2009 | 03:22 PM
Steven.'s Avatar
sounds like the distributor with no spark i was having the same problem, does the timing belt turn but doesnt fire up? change the distributor!
Old Jan 22, 2009 | 03:48 PM
chad olson's Avatar
yea i checked the red light on the ecu and it does not flash at all.. the dizzy does have spark but the ecu red light does not flash???
Old Jan 22, 2009 | 04:27 PM
mikeszutu's Avatar
If the car is refusing to go over 3,000 RPM it's likely it's in limp mode. Try resetting the ECU.
Old Jan 23, 2009 | 08:33 AM
chad olson's Avatar
how do you reset the ecu???and does anyone no wat a crank controll senor does????
Old Jan 23, 2009 | 08:43 AM
Header_whore's Avatar
change your ignitor..
Old Jan 23, 2009 | 10:36 AM
chad olson's Avatar
i changed the ignitor already and it does the same thing
Old Jan 23, 2009 | 11:48 AM
dennis's Avatar
Double check your grounds - the G101 (around the thermostat housing I think it is).
Old Jan 23, 2009 | 02:01 PM
chad olson's Avatar
i checked the grounds they are all good???could my ecu be causeing it???
boostedh22fag
Jan 18, 2013 12:30 AM
fastfox1306
Jan 29, 2010 10:34 PM
toys4red
May 22, 2008 03:57 PM
alwaystheking43
Jul 5, 2007 10:48 AM
soldham
Aug 18, 2006 05:50 AM
