Bouncy idle
Old Jan 18, 2009 | 10:05 AM
esean93's Avatar
Default Bouncy idle
im running a auto ls ecu in my manual eg.even if i do the auto to manual ecu conversion,will it still idle badly?will the rev limiter still be the same as it is?the ecu is auto and so is the motor.will i have to swap the manifold with a manual one if i get a manual ecu?
Old Jan 18, 2009 | 10:57 AM
esean93's Avatar
Default Re: Bouncy idle
cmon fellas my question has to be worth one response!
Old Jan 19, 2009 | 04:50 AM
Jimster480's Avatar
yes it will if u have the auto manifold u need to do the IACV fix. Because one of the wires on the 3 wire IACV go to the auto plug.
Old Jan 19, 2009 | 07:33 AM
esean93's Avatar
so how do i fix it exactly?
Old Jan 19, 2009 | 09:40 AM
Farmer89511's Avatar
Post Re: Bouncy idle
Just buy a manual ECU in the first place....
Old Jan 19, 2009 | 09:46 AM
esean93's Avatar
Old Jan 19, 2009 | 09:49 AM
oh okay i see my bad
Old Jan 19, 2009 | 09:51 AM
esean93's Avatar
its all good bro.
Old Jan 19, 2009 | 09:57 AM
lcsej1's Avatar
hold on. are you running a manual tranny? id say if your running a d series engine use proper ecu.
Old Jan 19, 2009 | 10:04 AM
esean93's Avatar
no im running a ls motor with ls tranny and auto ls ecu.the motor is an from a auto car but mated with a 5 speed tranny.i would swap the ecu with a manual one but id have to swap the manifold with a manual one too right?i can do the auto to manual ecu conversion but as jimster said ill still have to do a iacv fix.so my question is:how do i do the iacv fix?if you have a easier setup that you recommend then shoot.
Old Jan 20, 2009 | 05:26 AM
Jimster480's Avatar
there is a wiring diagram for a IACV fix on the auto harness. It takes a 3 wire and turns it into 2 by combining 2 wires on the harness. I have the diagram for it somewhere. You can also put a patch in your TB to bypass the IACV.
Old Jan 20, 2009 | 09:16 AM
esean93's Avatar
[QUOTE=Blk00EJ8;33526943]
You said you're using an OBD1 jumper harness, your stock OBD2B auto harness, and an OBD2A engine. Your problems most likely lies in your mish-mash of wiring. To start, you can use your OBD2B auto harness, but you need to do the IACV plug fix. Read this:
The OBD2A difference of the engine doesn't matter and your engine harness plugs into all the sensors fine.
QUOTE]
is this the iacv fix?let me clarify this so i dont screw up.if i do the iacv fix i HAVE to use a manual ecu.can i do the iacv fix and still use the auto ecu without having the idle problem?
Old Jan 20, 2009 | 09:19 AM
esean93's Avatar
Also,can i just cut the orange wire off of the 3 wire plug instead of getting a 2 wire plug and splicing.
Old Jan 20, 2009 | 01:18 PM
Jimster480's Avatar
lol really? ima do this fix. That way i dont have to get a manual manifold.
Old Jan 20, 2009 | 04:57 PM
esean93's Avatar
lol u have the same problem?also i cant run the auto ecu after i do the fix right?
Old Jan 20, 2009 | 06:01 PM
green99civic's Avatar
might wanna check your dizzy and make sure your timing is good that could cause rough ideal.
Old Jan 20, 2009 | 06:04 PM
esean93's Avatar
no its the auto thing because ive heard other people have the same problem when they do auto-manual swaps.
Old Jan 20, 2009 | 06:17 PM
gotcha man good to hear you figured it out
Old Jan 20, 2009 | 07:27 PM
Jimster480's Avatar
ya i have a crazy *** idle on my conversion. It starts around 2300 and finally gets down to around 1200.
Old Jan 21, 2009 | 04:18 PM
esean93's Avatar
yeah pretty much same here.i can do 35mph just idling but it starts to kick back and forth when the idle starts bouncing.
Old Jan 21, 2009 | 04:20 PM
esean93's Avatar
thanks man
Old Jan 21, 2009 | 05:02 PM
Jimster480's Avatar
ya mine just goes from like 3200 to 1000 and then goes lower sometimes. its just retarded as **** sometimes lol.
93civicsedan
Jan 23, 2009 11:31 AM
tturbocivic0618
13
Apr 15, 2008 01:40 PM
s73
May 29, 2004 11:17 AM
wpgcivic
12
May 27, 2004 12:20 PM
turboex
Apr 12, 2002 10:43 PM
