where do i find these fittings/plugs
Old Jan 18, 2009 | 08:42 AM
yoRt's Avatar
Default where do i find these fittings/plugs
where do i find the two port fittings for a breather setup, they bronzish ones that look factory?
i know z10 sells them but those are a little bit than i want to spend, wondering if they make oem ones that may be cheaper.
Old Jan 18, 2009 | 09:29 AM
Inliner's Avatar
Default Re: where do i find these fittings/plugs
well after a few minutes of searching..
Old Jan 18, 2009 | 10:29 AM
g230sport's Avatar
wait, what exactly do these do?
Old Jan 18, 2009 | 11:31 AM
Inliner's Avatar
using them for aftermarket breather system.
Old Jan 18, 2009 | 12:19 PM
yoRt's Avatar
thanks alot inliner, i still want the flywheel, if the weather isnt bad next weekend maybe we can work somethin out then.
Old Jan 18, 2009 | 12:35 PM
Unseen Racer's Avatar
sorry for the NOOB question but whats a breather system?
Old Jan 18, 2009 | 02:18 PM
teamworxek9's Avatar
^^^^ use the search option just like the op should have.
Old Jan 18, 2009 | 02:21 PM
Inliner's Avatar
basically your normal engine takes care of engine blowby on its own but on an Engine that you add a turbo to that doesnt come turbo your gonna have issues so you must let the engine breathe in a way that is still enviromentally sound. go in the forced induction section and do some research.
Old Jan 18, 2009 | 02:32 PM
lluks_844's Avatar
would these benefit more than welding fittings onto a valve cover? Or would it be just the same?
Old Jan 18, 2009 | 03:30 PM
laziebun's Avatar
dude i have two used one for your block, block plug for when removing your stock pvc box and two -10 for your valve cover. PM me if your interested
Okjis
Oct 27, 2009 08:29 AM
NuclearB18B
Jan 25, 2005 11:11 AM
Turbo D17
Dec 5, 2002 04:40 PM
jbraman
Sep 15, 2002 12:35 PM
