where do i find these fittings/plugs
where do i find the two port fittings for a breather setup, they bronzish ones that look factory?
i know z10 sells them but those are a little bit than i want to spend, wondering if they make oem ones that may be cheaper.
Re: where do i find these fittings/plugs
thanks alot inliner, i still want the flywheel, if the weather isnt bad next weekend maybe we can work somethin out then.
basically your normal engine takes care of engine blowby on its own but on an Engine that you add a turbo to that doesnt come turbo your gonna have issues so you must let the engine breathe in a way that is still enviromentally sound. go in the forced induction section and do some research.
dude i have two used one for your block, block plug for when removing your stock pvc box and two -10 for your valve cover. PM me if your interested
