Steering Wheel Shakes violently from 70+ mph -Searched-
Old Jan 17, 2009 | 10:43 PM
wlee112's Avatar
Icon6 Steering Wheel Shakes violently from 70+ mph -Searched-
When i am driving 70 mph and on up my steering wheel starts to violently shake [like maybe 10 knocks per second]. the wheel shakes as though there is metal clanking against each other [sounds like a "dack dack dack"]. From my searching i know everyone first assumes that its cuased by the tires, but since i've experienced this issues i've actually gone through two sets of tires(which i get balanced each time) and i always get an alignment after. During my last alignment visit, the mechanic did point out that the "bellow" boots on the driver side and passenger side needed to be replaced because they were torn off the tie rods.
might this be affecting anything? I've disabled the power steering for nearly four years now, but
the power steering rack still sits in my car. does anyone know whats really causing my issue...
Edit: So alot of people have been telling me that it can be my "rack end bushing" but i was previously thinking that i had a manual (non-power-steering) rack but i just noticed that power
steering racks dont have the rack end bushing
i looked online and i noticed that the power steering rack does also have another sort of a bushing at the end area of the rack end bushing ["BUSHING B, STEERING RACK" (Part# 53632-SF1-951)] would this bushing serve the same function as the rack end bushing on a manual racks?
http://www.hondapartscheap.com/south...t=0&quantity=0
Old Jan 18, 2009 | 12:43 AM
b18turbo210's Avatar
Default Re: Steering Wheel Shakes violently from 70+ mph -Searched-
had same problem .i did everything u did replaced all kinds of things tires,ball joints, tie rods and still had that shaking steering wheel until i changed my axle so u might want to check that out
Old Jan 18, 2009 | 01:46 AM
MIsterE533's Avatar
Check your struts, Main issue with this, You should see cupping or a wave like pattern on your tires from this issue. It's probably a blown strut due to the car being lowered. Put some struts on it designed for lowered springs, skunk 2's, tokico's. Whatever your fancy. Should cure your issue. Replace all four.
Old Jan 18, 2009 | 02:33 AM
FaceTuned's Avatar
also check your rack and pinion or replace there not to expensive at junk yards.
Old Jan 18, 2009 | 02:34 AM
99civicsiboosted's Avatar
check your tire/wheel balance and alignment also
Old Jan 18, 2009 | 02:52 AM
wlee112's Avatar
i doubt it is the rack and pinion because if that were messed up i'm pretty sure my steering would have play as i turned side to side. and i feel as though the point from which i start turning and the point from which i feel the pressure is a good shot distance [maybe only .5" to 1.0" of turning] and i dont have power steering so i'd notice that type of play immediately. correct me if im wrong.
you know what... this is probably the most suspect cause. becuase my cv boots did tear before from hanging turns in the twisties like a monster. but i brought the car to a friend at honda who said the axles still looked fine [i had actually just replaced the axles before i tore em] so all he did was just replace the cv boot alone refilling them with grease. but since you said you've had such a similar issue, perhaps you are my best bet thus far.
i also read around about my issue with my car shaking on acceleration. though its not a violent shake i definately feel a subtle yet significant amount of shaken amongst my entire car if im accelerating a little bit faster than granny speed (when you start torquing the motor) in maybe my 2 3 4 5 gears. i read that bad axles also attribute to that. i do not want to jump to any conclusions though
Old Jan 18, 2009 | 07:11 PM
wlee112's Avatar
bump
Old Jan 19, 2009 | 07:21 PM
HONDA RR's Avatar
I was in that similar situation. I replaced my upper control arm, inner tie rod ends, axle and still had that vibration on the steering wheel and some kind of a noise that was heard around the steering column area only while turning at low speeds and making a lot of 3 point turns or rocking the steering when at a complete stop. I was thinking it was the steering column itself and i drove my car to bear and frame which in a wheel alignment place and asked them to check the rack and pinion since that was the only thing i could think of. So one of the guys sat in the car and rocked the steering wheel from left to right and the other guy was holding the rack from underneath and said that the vibration is coming from the rack and concluded that it was the rack & pinion going bad. I found it hard to believe at first but when i did my own diagnosis by removing the whole steering column that is attached to the swivel joint on the rack. After removing the swivel joint that connects the steering column to the rack there is a slight movement on the shaft that is attached to the rack. So my only hope is to replace the rack on my 94 civic coupe and to do that i have to remove the whole subframe. BTW my car is equipped with a manual rack so the problem might be different for cars equipped with a power steering rack.
Old Jan 19, 2009 | 07:25 PM
bossm's Avatar
bro im sorry i cant help you on this one but when you said that your steering wheel shakes VIOLENTLY made me crack up the word violently is just to much lol sorry
Old Jan 20, 2009 | 09:50 PM
wlee112's Avatar
i never pass up an opportunity to give a fellow honda-tech'er a good laugh .
as far as the rack and pinion. my car used to be a automatic car but i converted to manual a while ago... how hard is it exactly to remove the rack and pinion? you made it sound as though i'd have to cut it out o.O
EDIT: I actually have a powersteering rack not a manual rack. sorry....
Old Jan 20, 2009 | 11:37 PM
Fook_me_honda's Avatar
You don't have to remove the subframe. Its a pain the ***, but there are directions on this site.
Pretty straight forward if you know what exactly your removing, the only problem i had was pulling it out because you have to turn the rack completely left (i believe) and then slide it out.
Old Jan 21, 2009 | 01:00 AM
B16AGUY's Avatar
Only other thing I can think of is engine torque mounts.
I know stock honda ones tear super easily and that can cause heavy shaking particularly at idle.
Old Jan 21, 2009 | 01:15 AM
Paul-R's Avatar
Wheel bearing .
Old Jan 24, 2009 | 11:29 PM
wlee112's Avatar
well if it were my rack wouldnt i experience some play when turning the steering wheel? life take maybe 5 degrees of turn side to side before i feel contact with turning the wheel cuase that actually feels really tight.
Old Jan 29, 2009 | 12:27 PM
wlee112's Avatar
any help?
Old Jan 29, 2009 | 03:53 PM
green99civic's Avatar
try re balancing your tires man i had the same problem and it was my tires
Old Jan 29, 2009 | 04:02 PM
slambedcivic's Avatar
axle... worn CV joints will vibrate like hell if they get too dry (ex. ripped boot)
and slow the f down. you dont need to do 70mph.
j/k.
Old Jan 29, 2009 | 05:47 PM
stiffinEK's Avatar
i just convert my 96 from automatic to manual also, and also i had power steering and also convert it to manual also.
one question i threw myself into while convert it. did you mess with the play on numbers 5, 6, 3, 4, 15 AND there should be a screwing nut that locks all of them into the steering mount? and also, there should be an under plate to cover the middle of the rack and pinion (DO NOT ELIMINATE THAT). its a support for it!
because when i went to pick-a-part and took out from a donor car, not knowing i wasnt supposed to mess with it. i took it apart thought that is one way to take out the whole rack and pinion, and finds out that messes up the whole stabilizer. and when i put it on my car while converting it, drove it, at 30+++ mph, my steering shakes like crazyy. it goes like 50 degrees left and right, and im wondering like wtf?
http://www.hondaautomotiveparts.com/...13S030_B33.gif
if so, you will have to get your whole rack and pinion rebuild or get a new or donor one.
and plus, its dead damn hard finding a manual rack i had to go on ebay to get one for $200.
http://cgi.ebay.com/ebaymotors/1998-...Q5fAccessories
let me know as soon as possible, because i dont want you to kill or hurt no one out in the streets, so as yourself mangg...
Old Jan 30, 2009 | 03:56 PM
turbo82's Avatar
Like he said. But check your tires first (wear and balance).
Had to replace the axle in my Jetta and SRT4 cuz of that.
Old Jan 30, 2009 | 04:39 PM
Ksanz's Avatar
somebody said it on here already...about 80% sure its a wheel bearing
Old Jan 30, 2009 | 10:28 PM
A bad wheel bearing will act up under non stress conditions. Like when going 60mph and you let off of the gas slightly. When you accelerate and hit the brakes it will go away. A bad wheel bearing feels very similar to a loose wheel.
Old Jan 31, 2009 | 12:01 AM
wlee112's Avatar
sometimes it doesn't shake when im traveling aroung 75 mph. today i was driving on the freeway and i noticed that it might not be very shaky until the freeway curves in a certain direction. I'll start to feel the wheel shake as it is turning then when i straighten out the wheel it starts to shake and knock with a klang klang klang noise. This vibration happens regardless of wether i'm coasting, accelerating or decelerating from 70+ miles per hour. so if the wheel bearing situation only applys to non-stress conditions i don't believe that will apply... anyone correct this?
Old Feb 2, 2009 | 09:00 AM
stevecod's Avatar
Hey, I have the EXCAT same problem as you 4 days ago. I jacked up the front of my car, took both wheels out, and start inspecting it. everything look fine accept for the inner steering rod on both sides. i could bacially pull on the steering rod in and out as far as 4"!!!!
went to the junkyards and got a pretty good lloking one and installed it and the car feels like a Lexus on the highway. no more shaking like crazy after 70+ mph.
try that and get back to us.
Old Feb 2, 2009 | 09:02 AM
stevecod's Avatar
just wanted to add that i changed the whole steering rack.
Old Feb 2, 2009 | 11:47 AM
Vindicator9000's Avatar
318 Curves, 11 miles
I had this exact same problem and it turned out to be a wheel out of round. It wasn't bent, but when I jacked the car up and spun it, it would wobble side to side. Moved the wheel to another corner of the car - same thing. Threw a steely on there, and it didn't do it. Replaced wheel, problem solved.
And that, my friends, is why Rotas are only $100 a wheel.
