Old Jan 17, 2009 | 06:02 PM
t_mac's Avatar
Default ****!
so i was taking apart my drum brakes... and then I decided not to go through with replacing shoes and drum. (still some life in them) anyways after a lot of struggling and some leaked brake fluid I got it back together properly. Anyways when I was doing it, I had a helper push the brakes on to pop out the rubbers on the wheel cylinder i was putting back together. Anyways I got it back together and thought well since I leaked out some oil. I should add more. I filled it up to the max line and applied the brakes slowly, then pumped them a few times. I find out that the wheel cylinder I had not been working on's rubbers have popped off so I put them back on pushed on the brake to make sure they stayed. I did manage to get the rubbers to stay on. the side I had taken apart- the drum went back on no problems. The other side which had not been dissaembled- the drum won't go back on. So I rolled the star wheel back al the way- the drum still doesn't go back on!! Now I don't know what to do... do I bleed the brakes? I can't see why this would help.. please experts. I need your help!!!! I'm losing confidence!!
*sigh*
Old Jan 17, 2009 | 10:58 PM
t_mac's Avatar
Default Re: ****!
ttt
Old Jan 18, 2009 | 06:25 AM
z6hatchboy's Avatar
Default Re: ****!
moving the brake adjuster is all you can do for the back, make sure the e-brake isnt on either
Old Jan 18, 2009 | 06:27 AM
t_mac's Avatar
Default Re: ****!
thats the thing I turned the adjuster all the way back. ie. its shorter then it was previously. Do I have to make it longer??? or do you think bleeding the brake lines would help?
Old Jan 18, 2009 | 07:32 AM
ek4_b16a's Avatar
Default Re: ****!
i wanna say, nice title. is the side with the untouched cylinder broken or what? will it push back in manually, by hand?
Old Jan 18, 2009 | 07:36 AM
Unseen Racer's Avatar
Default Re: ****!
no. bleeding the brakes wont do jack ****.
go to autozone and get one of those "drum brake calibrator" tells you exactly where the pads should be adjusted to for maximum braking
dwllama
Jun 8, 2017 02:23 AM
projekthonda02
Suspension & Brakes
Apr 15, 2012 03:13 PM
wolve
Suspension & Brakes
Mar 1, 2011 11:27 PM
mdmitch2
Jul 10, 2005 08:46 PM
DieMaster
18
Nov 9, 2004 07:41 AM
