Cluster swap.
Old Jan 17, 2009 | 12:49 PM
CokeZero's Avatar
Default Cluster swap.
looking to do a cluster swap in my 91 crx si, few noob questions.
will Any cluster work? (i can fab it to fit) if not which clusters will?
what all parts is needed to do the swap besides the actual cluster?
and last any links to a do it urself swap someone did?
thanks in advance!
Old Jan 17, 2009 | 04:23 PM
D16SiHatch's Avatar
Default Re: Cluster swap.
take a gander through this thread..
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/cluster-lets-see-them-2443255/
you'll need pinouts to match your stock wires to the new clusters plugs. and if its a newer cluster with an electronic vss reading you'll then need to install and wire up an electronic vss, in place of your stock cable unit.
Old Jan 17, 2009 | 04:37 PM
CokeZero's Avatar
thanks for the reply, since i have no idea whats required to convert a cable to VSS can u tell me what clusters are still ran on cable.. would a 94 teg cluster work? id be happy with that.
Old Jan 18, 2009 | 01:10 AM
D16SiHatch's Avatar
it uses an electronic vss reading. only thing that remained cable was 88-91 civics, and the DA teg. anything like 92 or newer is going to be electronic. wiring up the vss isn't hard though. if you're going to be moving all the other wires around, might as well do an elec. vss too. one wire is ground, another wire you run to ign power, and the last wire you tie into the clusters speedo input, as well as the original wire that went back to your ecu so it will know your speed. so long as you get each stock wire color to its corresponding new color on the new cluster plugs, you'll be fine.
Old Jan 18, 2009 | 12:02 PM
CokeZero's Avatar
how do u install the VSS itself? its as easy as just wiring it in? its not a unit that needs attached to anything?
Old Jan 18, 2009 | 03:51 PM
psychoward's Avatar
New User
the vss is pretty easy to swap. its on the back side tranny toward firewall it has a 10mm bolt holding it. remove bolt and turn vss back and forth and pull up.
Old Jan 18, 2009 | 03:53 PM
psychoward's Avatar
New User
make sure when you get the electronic vss you get the plug for it. The whole swap is pretty easy.
Old Jan 18, 2009 | 05:36 PM
CokeZero's Avatar
awesome thanks for the info. do i need to get the VSS from the car i get the cluster from?
Old Jan 18, 2009 | 07:37 PM
bprsk8r4272's Avatar
if you got a d series engine you'll need the vss off of a d series engine if you got a b series you need it off of a b series engine
Old Jan 18, 2009 | 07:53 PM
D16SiHatch's Avatar
close, but no cigar. both d and b-series utilize an obd1 d-series sensor.
Old Jan 18, 2009 | 10:00 PM
CokeZero's Avatar
H22 baybay :]
Old Jan 19, 2009 | 11:19 AM
CokeZero's Avatar
does it matter what gen prelude i get my vss off of? or as long as it has the h22?
jacksonww
May 4, 2009 10:41 PM
lopezchris21
Sep 18, 2008 11:40 AM
DA9kid
Feb 3, 2007 01:28 AM
cutt
Nov 12, 2004 06:57 PM
gvillehnut
Dec 30, 2002 05:26 PM
