tranny rebuilt but some rattle + vibrate??
Old Jan 17, 2009 | 12:47 PM
SkaiWu's Avatar
Default tranny rebuilt but some rattle + vibrate??
i've had a rebuilt tranny but i have rattles and vibrations thru it?
it feelslike theres stuff rumbling in there...
i feel the shifter vibrate normally and if i push it downwards just a little bit it also rattles/vibrates
help please?
the transmission been rebuilt w/ new gears syncros bearings etc everything and i JUST got it back today
thanksssss
Old Jan 17, 2009 | 01:26 PM
Targa250R's Avatar
be professional
Default Re: tranny rebuilt but some rattle + vibrate??
Originally Posted by SkaiWu
help please?
The internet isn't going to be able to help you nearly as much as the person who actually did the work for you . . .
Without being able to actually feel/hear/drive the car, anything we tell you here is a crapshoot.
Some vibration in the shifter is normal. Rattling noises can indicate the shifter hitting the exhaust or a loose shift linkage joint. Freeplay in the shifter can indicate a faulty spring pin at the shift shaft/linkage joint or faulty stabilizer bushings. Moverment in the shifter indicates bad engine mounts.
Your shifter is probably hitting the exhaust.
Old Jan 17, 2009 | 01:38 PM
HondaMotive's Avatar
+1
Couldn't have said it better myself. Heh
HondaMotive
WeakSauceEJ8
Sep 15, 2011 03:38 PM
DirTyPreTTyThinGs
Aug 15, 2007 08:35 PM
EG2Driver
Jun 7, 2006 02:49 PM
Sketch_hs
21
Mar 31, 2004 12:51 PM
