what part(s) do i need?? help!!
Old Jan 17, 2009 | 12:23 PM
kaj's Avatar
kaj
Default what part(s) do i need?? help!!
here are pictures from under the car:
as you can see there is a t-fitting (3) that has no line on it. i dunno why. should there be something connected to it?
i also have a larger-dia, rubber hose that is hanging down from the top of the fuel tank. it has a quick-disconnect end on it and it goes nowhere. i have no clue where it should be going.
i no longer have the hard line that goes under the car to the evap canister. i'm guessing one of the lines i mentioned above, go to the front?
i have called two acura dealerships. nobody knows how this system should be set up.
please help. i want my EVAP system put back together!!
kaj
Jan 18, 2009 03:04 PM
Homesickelian
Nov 18, 2006 09:55 AM
bassichonda96
Jan 26, 2006 06:29 AM
