Issue with cold?
I have a 95 DX with a D15 engine. Lately the temperature has been down to 0, if not -10. My car starts, and idles for around 10 minutes before it floods itself out. And after that it simply will not run..even if I give it a while and start it again it will do the same. It ran just fine when the temperature was 30 or above. I was wondering if maybe something is wrong that would cause it to pump more gas then needed if it's cold outside?
Edit: Today I'm hoping to get it into a friends heated garage and see if it will still run just fine in normal temperatures. I'm really hoping it's just something with the cold, but you never know.
well its fuel injected so the injectors wouldnt just dump alot of fuel into the combustion chamber unless the computer is telling it to i wouldnt think thats whats goin on..have u tryed to put DRY gas in as an additive. my car runs like poop right now to from it being cold i added dry gas and now its fine. exc on startup is slow
almostjdmeg
Jan 29, 2009 07:39 AM
accord___2000
Mar 7, 2008 04:03 PM
JDMlyfestyle
11
Dec 24, 2004 10:03 PM
