lug nut ?
Old Jan 17, 2009 | 08:50 AM
wesk18's Avatar
Default lug nut ?
i got two tuner lugs i cant remove using the tool that came when i bought the lugs, is there another way to remove this type of lugs? n with what type of tool is useful??
thanks
Old Jan 17, 2009 | 08:51 AM
YeuEmMaiMai's Avatar
Default Re: lug nut ?
did u over torque them?
Old Jan 17, 2009 | 08:53 AM
wesk18's Avatar
no, the hole is waisted n my tool slips, its worn n i need to replace
Old Jan 17, 2009 | 10:08 AM
P_Adams's Avatar
thanks
The only way I've been able to remove lug locks of this type is by welding a nut to the top of the lug and taking it off that way.
If you pack the area around the lug you're working on with wet towels, you won't damage the rim (unless they're really, really countersunk).
P
Old Jan 18, 2009 | 02:49 PM
dleccord's Avatar
P
how do you take off the weld?
Old Jan 18, 2009 | 03:03 PM
TheMuffinMan's Avatar
He knows where you live!
Sears usually has a thing that looks like a damn alligator's mouth It just digs into the side of the lug and lets you take it off.
Old Jan 18, 2009 | 03:20 PM
erk89's Avatar
You dont, you get new lugs
Another cheap way is to hammer a socket on it and hope it takes it off.
Old Jan 18, 2009 | 03:34 PM
P_Adams's Avatar
x2 ... and certainly NOT another set of these!
P
Old Jan 18, 2009 | 09:12 PM
f22vtecswap's Avatar
x3 dont get those locks they are nothing but problems
Old Jan 19, 2009 | 06:35 PM
dleccord's Avatar
so you're saying one can steal rims even if they have the special lock lugs?
Old Jan 19, 2009 | 06:53 PM
There's always a way depressingly
Old Jan 19, 2009 | 07:49 PM
P_Adams's Avatar
Sure, if they want them bad enough
If they stole the whole thing, they'd have all manner of time to work on it.
Old Jan 19, 2009 | 07:57 PM
dleccord's Avatar
i bet they're gonna try to take off the fender/panels first and the control arms. hah.
Old Jan 20, 2009 | 03:46 AM
doubleRdazz's Avatar
what i did on a car one time was took all the other lugs off then pryed the wheel away from the hub as much as i could and cut the stud off with a airsaw
pain in the *** but it worked
and i only had one broken lug, that might not work for you since you said you have two damaged
i would try the welding idea that sounds like it will def work
Old Jan 26, 2009 | 10:28 PM
wesk18's Avatar
got a easier way i guess, use a drive extension a slighty bigger size than the original tool. hammer it in half way n then use a power tool or manual tool
Old Jan 27, 2009 | 06:13 AM
TouringAccord's Avatar
H-T Order of Merit
there is no stopping a determined thief. The best thing you can hope to do is to slow them down enough that they decide it's taking too much time and give up.
Old Jan 27, 2009 | 04:44 PM
wesk18's Avatar
i want to buy that tool, u know a place i've seen it u stick it in the hole hammer it, and the it grips itself from the inside of the lug so it could be easier to take off
Old Jan 27, 2009 | 04:45 PM
wesk18's Avatar
yea, true true but then it could get ugly they will be so pist theyll trash ur car or something
Old Jan 27, 2009 | 05:07 PM
H-T Order of Merit
eh, whats the difference if they trash it or steal it and you never get it back anyway?? I'd rather deal with a trashed car than a car you'll never see again because even if your insurance says it's a loss at least the thieves didn't get anything out of it.
there are always a whole bunch of those "what if" type situations.
SupaMonkey
Dec 20, 2013 12:18 AM
blaze.1
Oct 5, 2009 05:51 AM
ildknyli
Oct 3, 2006 09:08 PM
billyhoe
May 18, 2005 02:23 PM
BrandonClaps
Aug 29, 2002 08:50 PM
