h2b tq specs
Hello guys, I bought a qsd h2b kit for an EK few months ago. I installed and everything but motor didn't work after. Make the long story short, I threw ago the install manual (being a dumbassss that I am..) and now i don't know any of the tq specs to bolt the kit down Also the clutch specs. I have emailed qsd... called... many many times for the past few days... but no1 picks up or respond. I wantt to finish the car but can't. If somebody has it or know the tq down specs can you help me? Thanks.
im sure seth is busy with his family, work and trying to finish up the race car so his response might be slow. somebody here will have the imformation you need real soon.
flywheel bolts- 40-65-95 ft lbs
8mm hex-head-35 ft lbs
2 60 mm on backside of engine that secure directy into adapter plate-37 ft lbs
all other adapter plate bolts-35 ft lbs
half-shaft adapter 10mm bolts-30 ft lbs
half-shaft adapter 3 12mm bolts-40 ft lbs
engine mount adapter 10mm bolts-37 ft lbs
THANKS SO much SIXTY. That really helps me. I know Seth is busy and everything so thats I didn't no hard feelings against him or anything at all. Thats why I asked for people' help like you. Finally I can continue on... Thanks alot
