where is the FUSE on the ebay fog lights 99-00
hey i got an em1, my foglights went out and i cant seem to figure out whats wrong, i want to check the fuse but does any1 know wher ethe fuse is located? thanks
btw, i relocated the ground near the driver side fog light to a different part of the chassis, and it worked (only the driver side worked), earlier i turned on the switch and neither of the lights work again so i think it might be the fuse. thanks
actually theres an update, i re routed the ground wire again and now my driver side fog works again. but i sitll need to know where the fuse is. thanks
Well if one fog light is working then it's prolly not a fuse, Does your wireing have two grounds on it? One for eatch fog light? if so try re routing the other ground.
The fuse is located on the harness near the foglight switch and the relay. Just remove the panel below the steering wheel and you will see it.
traxxasx
10
Aug 10, 2009 01:28 PM
I8ayellowcrayon
21
Sep 1, 2005 01:34 AM
