Lighting HID/Xenon kits, Retrofits and Associated Topics
Retrofit HID ballast wire meltdown!
Old Jan 16, 2009 | 12:59 AM
jdmej814's Avatar
Icon3 Retrofit HID ballast wire meltdown!
well i need a solution here from you guys, tonight while coming home, my ballast somehow managed to get off its position, screw came off :S, and the ballast ended up being stuck in my block, it burned the POWER wire for the ballast and that wire looks unreplaceable.
do i need to pick up new ballast?
any other solution than buying new ballasts?
Old Jan 16, 2009 | 02:47 PM
jdmej814's Avatar
Default Re: Retrofit HID ballast wire meltdown!
ttt
Old Jan 16, 2009 | 03:02 PM
importdude2000's Avatar
u should be able to fix it
its just a circuitboard
that has a power pin/part on the board that u can solder to
Old Jan 16, 2009 | 03:09 PM
-Bionic-'s Avatar
Former Sponsor
You are talking about the igniter wire correct?
That is really just one power wire with either one or two ground wires.
You can solder it together, but to be on the safe side pick up another ballast.
What ballast did you use. We carry tons of parts, and I can certaintly send you just one ballast.
Bjorn
Old Jan 22, 2009 | 08:57 PM
98civdx's Avatar
Master Detailer
cut the two ends and re connect them add wire if needed.
mine almost the same,
my wire hit my pulley and melted,,
check fuses, mine blew.
buzzsawstan
Jun 30, 2004 09:09 PM
R0476
Mar 8, 2003 08:54 PM
91cvcsi
Oct 8, 2002 12:17 PM
