Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
DIY: OEM Fogs on with Parking & Highlights
Old Jan 15, 2009 | 11:15 PM
SHG_James's Avatar
Default DIY: OEM Fogs on with Parking & Highlights
!!!This does not apply to replica foglight kits!!!
This was done on a 04 Civic. 01-03 Civics might be similar.
1. Disconnect the negative terminal on the battery
2. Remove the steering column garnish, fusebox panel & center console.
3. This is how to make your foglights stay on with the highlights. De-pin this wire (red/white) from the headlight switch harness.
4. Ground this wire anywhere you choose. Congrats! Your foglights now stay on with the highlights.
5. Now, to be able to turn on the foglights when only the parking light is on you have to do the following. Disconnect these bundle of wires in front the center console.
6. Keep the foglight bundle aside and reconnect the oem bundle together.
7. You may think there's a lot of wires, but there's not. If you remove the tape where the loom joins, you'll only see one wire (red/ylw). That goes to the relay.
8. Cut where the loom joins to the bundle of wires. You'll only need this part of the harness.
9. In the center console area, there's a bundle of wires going to the back. Within this bundle there's 2 red/ylw wires. With your multimeter, check which one of these red/ylw wires passes a 12v current when the parking lights go on. Strip the skin off that wire. As you can see i stripped the wrong one :p
10. Solder the red/ylw wire coming from the relay to the red/ylw wire you just stripped.
11. Congrats! Your foglights now stay on with the highlights & can come on with the parking lights.
Old Jan 16, 2009 | 07:14 AM
EM2_08's Avatar
Default Re: DIY: OEM Fogs on with Parking & Headlights
nice write up
Old Jan 16, 2009 | 10:42 AM
texasnick's Avatar
Default Re: DIY: OEM Fogs on with Parking & Highlights
nice DIY. Very well written.
Sticky?
Old Jan 16, 2009 | 12:47 PM
SHG_James's Avatar
it will eventually be in the FAQ, but since toyomatt doesn't mod the forums much it might take a while
Old Jan 16, 2009 | 12:49 PM
texasnick's Avatar
How different is this installation with the use of a switch?
People up here usually get pissed off when you drive around with your fogs on lol....jerks
Old Jan 16, 2009 | 12:54 PM
SHG_James's Avatar
this is the OEM foglight kit, so a switch is already wired in. this DIY shows you how to rewire the harness so you can choose to have the fogs on ANYTIME as long your parking lights are on. the OEM fog harness only allows you to have the fogs on when your low-beams are on, which defeats the purpose of have foglights since you want the low beams off and the fogs only on in the event of heavy fog or rain
Old Jan 16, 2009 | 12:58 PM
It Wasn't Me's Avatar
Added to FAQ's
Old Apr 13, 2009 | 10:48 AM
ApexRR's Avatar
New User
nice DIY write up!
Old Apr 13, 2009 | 03:32 PM
mycar95gsr's Avatar
write up
Old May 8, 2009 | 07:21 PM
MC25's Avatar
Thanks for the write up, im looking forward to installing a set of these.
Old May 28, 2011 | 09:04 AM
EM2Ninja's Avatar
Very helpful write up, thank you
Old May 29, 2011 | 10:22 AM
mycar95gsr's Avatar
damn back from the dead lol
Old May 29, 2011 | 01:13 PM
theineffable's Avatar
Heh my genuine oem Honda Canadian fogs already allow me to turn them on without the headlights or parking lights being on..
OH honda boy
Sep 28, 2009 07:28 AM
mortificationrock
Audio / Security / Video
Jun 6, 2008 10:13 PM
scorp965
Apr 10, 2006 01:15 PM
EeeJayEight
Aug 30, 2004 06:41 AM
jdmstreethatch
Jan 20, 2004 06:50 PM
