help plz. obd2 dizzy to obd0 harness
Old Jan 15, 2009 | 09:35 PM
alx_90ef's Avatar
Default help plz. obd2 dizzy to obd0 harness
OK so here's the situation
i have an ef with a d15z1 but i need a dizzy for it.
with and OBD2 sohc vtec distributor work for it?
im keeping my stock si harness how can i make it work?
Old Jan 15, 2009 | 10:13 PM
D16SiHatch's Avatar
Default Re: help plz. obd2 dizzy to obd0 harness
as long as you are running it with an obd1 ecu , then an obd2 diz will work. you just have to depin and change the connections.
Old Jan 15, 2009 | 10:14 PM
crx_si-r's Avatar
as long as you are converted to obd1 and repin the obd2 dizzy to run in obd1 then yes. if you just have the vx motor and are running everything obd0 then you will need to get another 88-91 TD-02U distributor.
Old Jan 15, 2009 | 10:44 PM
93formula's Avatar
why did you post the same question twice??!!
Old Jan 16, 2009 | 10:56 AM
alx_90ef's Avatar
im going to keep my stock ecu
will the obd2 dizzy work ?
Old Jan 16, 2009 | 11:22 AM
4drEF's Avatar
Keyboard Humorist
No... OBD2 dizzy won't work.
The reluctor wheel inside has a different tooth count and ultimately sneds a different count of electrical pulses to the ECU. OBD2 and OBD1 have the same pulse count, OBD0 is different.
Old Jan 16, 2009 | 11:45 AM
CRX Toad's Avatar
One thread for this question only. OP please DON'T post same question multiple times.
Use Your Original Thread
diviznrider
13
Apr 19, 2019 01:38 PM
grodzef9
Jun 19, 2008 10:32 AM
DIYMIKE
Feb 23, 2007 09:06 PM
97DGreenEx
Oct 13, 2006 06:21 PM
inline4
15
Sep 9, 2003 03:03 PM
