gsr help
Old Jan 15, 2009 | 07:51 PM
cudaben's Avatar
Default gsr help
just put a obd 1 gsr with a b16 head and jdm b16 intake in my dc2. got the right v-tec sol. and dist. but now i am having some bad idling issues. It sits at 2k for idle then starts bouncing up and down irratically. whf? tried to track down a vacucm leak cant find one. swapped all the "new" sensors off the engine for my old ls ones that i know work and no change. swapped the throttle body and the same thing. what gives?
Old Jan 15, 2009 | 07:56 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: gsr help
Remove the intake, start the car, and seal the TB with your hand. if it keeps running, you have a vacuum leak.
Old Jan 15, 2009 | 07:59 PM
GSRalive's Avatar
Do you still have the B18C1 intake manifold on? If so then there is an idler air box on the back of that intake. If that is dirty, that could be the problem. But it sounds like your TPS (throttle positioning sensor) might be malfunctioning...recommend changing it out for a new one.
Old Jan 15, 2009 | 08:01 PM
Dogginator's Avatar
Daisy... Daisy...
I like to diagnose the problem before i start swapping random parts. For the TPS, it would be in the OPs best interest to check the voltage profile first. I highly doubt that it is at fault.
Old Jan 15, 2009 | 08:40 PM
cudaben's Avatar
i had an extra tp so i swapped it, i swapped the iac and no b18c intake, just a b16b intake jdm one. its what i go the head from, i got a complete b16b and used the head on my gsr block. the b16b had a bad rod bearings and rings. no i dont have it anymore. after swapping thoses parts it still did the random idle, its even shot up to 4k so far. wtf????? seriously i'm f*ing puzzled
Old Jan 16, 2009 | 04:34 AM
cudaben's Avatar
nobody knows what is going on... shi*... guess i'll have to drag it off to honda to get worked on.
Old Jan 16, 2009 | 04:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Do you really think the techs at your local Honda dealer have any in-depth engine swapping/hybrid troubleshooting experience? If so then that's cool, but if not then eh... probably not a good idea to take it there.
Of course I would never take my car to the dealer for service anyway, unless it was under warranty.
Old Jan 17, 2009 | 08:09 PM
cudaben's Avatar
patrickgsr94 thanks for that insightful thought.... wow because of you i can now fix my car!!!!
moving on, turned out i had the iac plug wired backwards... oops. fixed, motor rips hard now!
Old Jan 18, 2009 | 05:48 AM
Dogginator's Avatar
Daisy... Daisy...
Spliced harnesses can cause a world of issues.
UndergroundTuning
Feb 15, 2010 11:48 AM
Famous94LS
Apr 16, 2009 06:34 AM
newtype_racing
Oct 10, 2008 11:03 PM
90crxdriver
Jun 24, 2007 03:32 AM
E-spec Tuner
Jun 22, 2003 01:26 PM
