quick VSS Question
Old Jan 15, 2009 | 05:32 PM
BLU CIVIC's Avatar
Track Advocate
Default quick VSS Question
swapping in a GSR cluster into my 91 Civic and just want to know if this VSS will fit my LS transmission
Originally Posted by ryc555
came off d16z6 m/t but i believe on obd1 there is no difference between a/t and m/t.
Old Jan 15, 2009 | 05:55 PM
D16SiHatch's Avatar
Default Re: quick VSS Question
yep it sure will. thats exactly what you need.
I put this together when i did my ls cluster swap, and if you dont already have a decent pinout, this might be of use to you. also wanted to note whether you have a ls/gsr/or type r cluster, the wiring to the new blue integra plugs remains the same.
and this might also be helpful lol
Old Jan 15, 2009 | 06:10 PM
BLU CIVIC's Avatar
Track Advocate
it's a GSR
Old Jan 15, 2009 | 07:56 PM
D16SiHatch's Avatar
i know this. i can read lol. like i said the pin out does not change regardless of whether its a ls, gsr, or type r cluster.
Old Jan 24, 2009 | 09:48 PM
BLU CIVIC's Avatar
Track Advocate
will that VSS work on D series transmissions?
Old Jan 24, 2009 | 11:52 PM
Clipsed's Avatar
kinda glad this post came up. Why does the VSS signal wire have to go to the ECU AND the cluster?
Any way of hooking up the gas light?
Old Jan 25, 2009 | 06:14 AM
punkdown's Avatar
Because stock the cluster converts the rotation of the cable into an electric signal that gets sent to the ECU. For the electric VSS you have to send the signal to both ecu and cluster. It doesn't matter where you run the new wire to... if you've already done a MPFI or OBD1 conversion it would probably be easier to run the new wire to the ecu and splice it in there.
As for the gas light I think you have to get a low fuel warning sender from an Integra as the CRX/Civic's didn't come with them.
Old Jan 25, 2009 | 04:26 PM
Clipsed's Avatar
cool, thanks for the info!
Old Oct 5, 2009 | 06:01 AM
1cleanef91's Avatar
thanks for the vss pinout works perfect i was so happy some dumbass gave me the wrong diagram thanks though
SweetChinMusic
Feb 18, 2013 08:26 AM
graftuner34
Aug 22, 2008 09:04 PM
iTzKeviN
Sep 6, 2005 02:28 PM
DsBananas94LS
Jan 10, 2005 08:30 PM
flat-blk-HB
Oct 31, 2003 08:05 PM
