where is vehicle speed sensor located
Old Aug 6, 2002 | 11:40 AM
GRAVEDIGGER's Avatar
Default where is vehicle speed sensor located
as well as voltage regulater . thanks
Old Aug 6, 2002 | 11:42 AM
Spade's Avatar
Default Re: where is vehicle speed sensor located (rp2000r)
VSS is on the tranny.
Old Aug 6, 2002 | 11:44 AM
Spade's Avatar
Default Re: where is vehicle speed sensor located (Spade)
Votage Regulator is on the alternator.
Old Aug 6, 2002 | 01:14 PM
thanks Spade , but what exactly does the vss look like and how do i know if it needs to be replaced or if it is bad , ido have a check engine light. Also where is it exactly is it on the tranney thanks
Old Aug 6, 2002 | 01:15 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
does your speedo work?? any problems with it? what code are you getting??
later
matt
Old Aug 6, 2002 | 01:35 PM
Default Re: where is vehicle speed sensor located (champITR)
iam getting codes 17,41 ,65 vss and oxyegen sensors . Speedo jumps erratically from 0-120 sometimes, but after a bit of driving it will start to read the speed acurately also lights pulsate , not during idle but if i tap the gas over say 1200rpms or so they pulsate haevely but just like the vss after about 10 minutes or so of driving the pulsating stops .any ideas???????
Old Aug 6, 2002 | 01:50 PM
BROOD's Avatar
This is what the VSS looks like numbers 7 or 8, located towards the rear of the trans.
[Modified by SLPR, 2:51 PM 8/6/2002]
Old Aug 8, 2002 | 11:30 AM
Default Re: where is vehicle speed sensor located (SLPR)
how do i remove vss and also could you show me what the voltage regulater looks like and how to remove and also how do i know if sensors are bad ?thanks
Old Aug 8, 2002 | 11:40 AM
Malachi's Avatar
for vss, remove #14, a 10mm bolt. then pull it straight out.
Old Aug 8, 2002 | 12:08 PM
Marauder's Avatar
Not to be an *** or anything.....
But if you want to do this type of work yourself, I would suggest getting a repair manual.....they are very useful!
They can also help you check whether a sensor is good or not
Tank_EM2
Honda Civic (2001 - 2005)
Jul 1, 2014 03:28 PM
kindness
Aug 31, 2012 11:20 AM
ixoiiiiviviiivi
Jul 15, 2008 09:21 PM
aziaticvang
Jan 13, 2008 06:35 PM
turismo128
Sep 27, 2005 03:22 PM
