where is vehicle speed sensor located
Re: where is vehicle speed sensor located (Spade)
thanks Spade , but what exactly does the vss look like and how do i know if it needs to be replaced or if it is bad , ido have a check engine light. Also where is it exactly is it on the tranney thanks
Location: If ignorance is bliss... I am in the happiest, place on earth.
Re: where is vehicle speed sensor located (rp2000r)
does your speedo work?? any problems with it? what code are you getting??
later
matt
later
matt
Re: where is vehicle speed sensor located (champITR)
iam getting codes 17,41 ,65 vss and oxyegen sensors . Speedo jumps erratically from 0-120 sometimes, but after a bit of driving it will start to read the speed acurately also lights pulsate , not during idle but if i tap the gas over say 1200rpms or so they pulsate haevely but just like the vss after about 10 minutes or so of driving the pulsating stops .any ideas???????
This is what the VSS looks like numbers 7 or 8, located towards the rear of the trans.
[Modified by SLPR, 2:51 PM 8/6/2002]
Re: where is vehicle speed sensor located (SLPR)
how do i remove vss and also could you show me what the voltage regulater looks like and how to remove and also how do i know if sensors are bad ?thanks
Not to be an *** or anything.....
But if you want to do this type of work yourself, I would suggest getting a repair manual.....they are very useful!
They can also help you check whether a sensor is good or not
ixoiiiiviviiivi
07-15-2008 09:21 PM
