need help! 02 sensor (tried everything!) and airbag light are on.
Old Jan 15, 2009 | 03:39 PM
blacksoul's Avatar
Icon3 need help! 02 sensor (tried everything!) and airbag light are on.
i have an 04 civic si. i gutted the cat (dumb) and check engine light came on. I bought an o2 sensor simulator from casper electronics. The light stayed on. And now i have installed 2 of those o2 sensor spacers/extenders that keeps the o2 sensor out of the exhaust pipe. The light stayed on. I bought a diagnostic scan tool to clear the code, but it comes right back on. Now my question is, do you think the o2 sensor is bad and needs replaced? What should i do? Open to any suggestions, and yes i searched......ALOT!
About the airbag, i unhooked the connector under the seat to try to make the seatbelt alarm quit beeping. Then the airbag light came on, and i hooked the connector back up. Reset the ECU, and light has been on ever since. Anyone know anything bout this? THX.
Old Jan 16, 2009 | 09:25 AM
DaveSi677's Avatar
Default Re: need help! 02 sensor (tried everything!) and airbag light are on.
You need a new o2 sensor... I need one too but right now I don't have the 255$ Honda quoted me for the part!
Old Jan 16, 2009 | 09:36 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
buy a denso 02 from an autoparts store.
you need to reset the srs light. big pain in the ***. Just wear your seat belt and it won't beep. Hell it may even save your life someday cool guy.
Old Jan 16, 2009 | 12:14 PM
blacksoul's Avatar
yeah ive come to the conclusion that i need a new o2 sensor. i guess theres no way around the 200 and something dollar o2 sensor?
And how do i reset the srs light? Or is that something i can do?
I always wear my seat belt now.
Old Jan 16, 2009 | 12:40 PM
DaveSi677's Avatar
Do you know how much the denso o2 sensor goes for about?
Type-Spaz's Avatar
DC5/EP3 MOD :)
Quick Read DIY without pictures:
1. connect clip to yellow clip, turn key to position II
2. wait for the light to go off and remove the paper clip/wire.
3. As soon as the light turns back on, quickly connect the circuit again.
4. The light should turn back off. Remove the paperclip/wire again.
5. The light will wait a second or two before it tells you the follow word.
6. Final word is, 2 quick flashes and SRS light turns off completely.
6-A. two quick flashes and the light remains, you may be too slow or you have a short in your SRS somewhere.
7. turn off ignition and put back the clip.
Congratulations, you have successfully reset your SRS light.
for more info go here
http://forums.clubrsx.com/showthread...rs+light+reset
slow_low_eddie
Honda S2000
Jan 19, 2015 07:45 PM
skuba
Engine Management and Tuning
Jan 18, 2010 05:45 PM
mierock
Honda Civic (2001 - 2005)
Jan 7, 2009 02:55 PM
92integraVTECgsr
Jan 21, 2008 07:48 AM
boosted111EG
Jul 5, 2007 07:42 PM
