stupid question
ok.. cleaned out the cig lighter and blew a fuse. it controls the radio as well..
looked all over for the radio fuse but its not labeled.
what fuse is it??
98 accord lx 4cyl.
thanks.
also i looked in the honda manual and haynes NEITHER TELL YOU
thanks again
what fuse is it??
98 accord lx 4cyl.
thanks.
thanks again
1998 - 2002 Accord:
Under dashboard - right side
There should be a fuse diagram on the under side of the fuse box cover
P
There is also a fuse box under the hood, passenger side near the firewall (at least there is on mine, which is a 2000 V6). In the under hood fuse box, the radio is controlled by the "Accessory" fuse which I believe is labeled "Acc". I think it is a 40A and actually sits a little bit higher than the other fuses in that box.
xxkido0xx
15
Dec 1, 2008 07:56 PM
netanderthal
Jan 20, 2006 03:12 PM
