need valve adjust procedure for F22 non vtec one in faq dead
Old Jan 15, 2009 | 02:16 PM
masterkill455's Avatar
Default need valve adjust procedure for F22 non vtec one in faq dead
I need to adjust the valves on my 96 with an F22 but I need the adjustment procedure and the link in the faq for the procedure has died
Old Jan 16, 2009 | 07:07 AM
jweller's Avatar
Default Re: need valve adjust procedure for F22 non vtec one in faq dead
heres a really good one for a b18. Obviously there are some differences, but it generally applies. the correct lash specs should be on a sticker on the underside of the hood.
http://www.c-speedracing.com/howto/v...alveadjust.php
Old Jan 16, 2009 | 12:01 PM
thank you jweller. going to adjust my valves this weekend. What about replacing the spark plug tube seals, are they just in the valve cover?
Old Jan 16, 2009 | 01:02 PM
GhostAccord's Avatar
Icon6 Re: need valve adjust procedure for F22 non vtec one in faq dead
Here is the proper method for the SOHC F22B2 valve adjustment.
As for the tube seals there are two sets.
Yellow are the valve cover seals
Red are the spark plug tube o-rings.
Didn't you already started a thread about this?
Old Jan 16, 2009 | 07:26 PM
sorta that wasnt the original purpose of the old thread but I took the voltage problem out because I fixed it already. Sat I will be doing my valve adjustment and Im gonna take pics and make a write up on how to do it, before I even saw your reply I got my hands on the adjustment procedure off of alldata through a shop i used to work at. So im gonna make a thread with some pics and with the instructions from alldata. Thanks for you help though, and im thinking yes this adjustment will fix my annoying tick but do you think it will fix my bogging? My car recently started to bog on initial take off unless you accelerate lightly, it will bog down for a second then rev up, I kinda think its a dirty TB and im sure changing the fuel filter wont hurt anything but just curious if valves might do it.
Old Jan 16, 2009 | 07:44 PM
bluetintruben's Avatar
You should find a snap on dealer or matco dealer and ask for the tool to adjust over head cam valves. they're like 30 bucks and way worth it. makes the procces way easier.
as far as the bog, check fuel pressure and maybe your regulator. Could be showing signs of age.
Old Jan 16, 2009 | 07:45 PM
http://buy1.snapon.com/catalog/item....re&dir=catalog
heres your tool
Okay I was wrong. its more like 60 bucks.
Old Jan 16, 2009 | 08:05 PM
Powerbuilt Honda Valve Adjustment Tool - 10mm Jam Nut
Product #: 648827-Powerbuilt
List Price: $32.43 online price $21.22
I'm pretty sure you can get them at any auto parts store for well under $40. You don't need a $60 Snap-on tool for the one or two times you are going to do this job.
Old Apr 2, 2009 | 11:26 AM
accord_raffi's Avatar
anyone know if there is a thread on here that has the torque specs for the camshaft assembly bolts because i have to get at the lower seals.
square_1
May 2, 2011 09:37 PM
Blindeye_03
11
Mar 10, 2010 03:29 AM
Robotoyaki
Jan 1, 2010 02:10 PM
tr3-2001SE
Nov 28, 2005 09:48 PM
dacaveman
Jul 20, 2004 10:02 PM
