still not running good
Old Jan 15, 2009 | 02:59 AM
nkhd's Avatar
Default still not running good
changed head gasket, timing belts, oxygen sensor,
Car should be running good.
changed the o2 sensor because of code and timed it last night.
when driving it has a bad miss and jerks alot then smooths out and runs fine then starts missing/jerking again.
What did I do wrong or forget to do????
intake air leak?, loose timing belt?bad igniter??
Old Jan 15, 2009 | 03:37 AM
gasha1's Avatar
Default Re: still not running good
Sounds like a ground or vacuum problem. Does it happen at the same speed, temp, gear?
Old Jan 15, 2009 | 04:07 AM
P_Adams's Avatar
Fouled Spark Plug?
Marginal Ignition Cable?
Will the engine do this either at or just above idle?
P
Old Jan 15, 2009 | 05:05 AM
nkhd's Avatar
all gears and minimally at idle
Old Jan 15, 2009 | 05:35 AM
nkhd's Avatar
at idle it wasn't jumping time but after i test drove it and it was jerking I put the timing light back on it and it was still timed but it was jumping time now and then
Old Jan 15, 2009 | 05:43 AM
1grex's Avatar
plug wire or other ignition
[S]niper[W]olf
May 19, 2015 06:06 AM
silicondt
Apr 14, 2015 01:51 PM
gabrielsousa
31
Aug 18, 2014 04:20 AM
Samahi72
Feb 9, 2009 12:59 PM
KooK
Nov 19, 2005 02:54 PM
