Energy suspension bushing kit
Old Aug 6, 2002 | 10:52 AM
Ek4 B16A2's Avatar
Default Energy suspension bushing kit
Hello
I would like to know what do you think about this kit for a Civic EG with B16A2 to make circuit ?
Thanks a lot.
Old Aug 6, 2002 | 11:20 AM
Spade's Avatar
Default Re: Energy suspension bushing kit (Ek4 B16A2)
Circuit?
Negative = Ground. Does that help?
Seriously what the hell do you mean?
Old Aug 6, 2002 | 10:32 PM
Ek4 B16A2's Avatar
Default Re: Energy suspension bushing kit (Spade)
I am French and I prefer driving quickly on a circuit. We have several circuits on the country. I live near a circuit (20 kilometers)
It is too dangerous on the street (police and others drivers).
Old Aug 6, 2002 | 10:51 PM
TDRacing's Avatar
It tightens up the car pretty good, you will notice it more if your car is older. I would only do it if you need to replace the bushings.
Old Aug 7, 2002 | 03:51 AM
Civic1992DX's Avatar
Default Re: Energy suspension bushing kit (TDRacing)
1. it's a mess to replace all rubber bushings with poly
2. car handles much better
3. you will hear/feel each crack on the pavement & it will be almost impossible to drive on the european brick-paved city streets.
Yuri K
Old Aug 7, 2002 | 03:59 AM
Ruby Civic's Avatar
well, i put them on my 91 civic sedan and was VERY pleased with the sharpening in handling along with sway bars, struts, springs, etc. and have survived on the mean streets of DC for some years with only minimal squeeking - happy overall & very fun to hit a corner hard and accelerate through it where all aother street cars are braking....
Old Aug 7, 2002 | 05:23 AM
92sleepR's Avatar
New User
It does help tighten up the car. A worthwhile upgrade
They squeek like micky mouse getting raped if you don't keep them lubed up
They are a pain in the *** to install if you do it yourself and expensive if you have someone else do it.
If you are looking to dramatically improve the handeling you should seriously look at the radius arm setup by Z10 http://www.z10eng.com/products.cfm#rat1
Hope this helps
Mike
Old Aug 7, 2002 | 08:18 AM
rolow's Avatar
Default Re: Energy suspension bushing kit (92sleepR)
Sandpaper helps with the squeaks
Yes I am serious the shinny surface of the bushings are part of the manufacturing process and don't let the poly self lubricate which is is supposed to do. You use the sand paper to dull up the surface then lube them with the grease they give you and you should be fine.
Old Aug 7, 2002 | 09:11 AM
TDRacing's Avatar
Default Re: Energy suspension bushing kit (rolow)
If you are going to do it, get a shop to, they are a pain in the *** to get them all out.
Old Oct 11, 2002 | 04:35 PM
ragejed's Avatar
Not a bad Idea, ill do this. What grease should I use?
jdm_sai
Suspension & Brakes
32
Feb 27, 2015 10:04 AM
91GEDHATCH
Suspension & Brakes
25
Aug 12, 2011 07:05 AM
93preludeh22
Oct 4, 2008 06:18 PM
20vsleeper
Suspension & Brakes
Jul 13, 2007 08:10 AM
Kellindal
Dec 24, 2001 07:32 PM
