TW: SOHC fully built turbo swap
Old Jan 15, 2009 | 01:24 AM
kinkyintegra's Avatar
Default TW: SOHC fully built turbo swap
Just seeing if any interest in my setup before i go swap it into one of my cars.
D16z6 40k+
Darton Sleeves 75mm Closed Deck
Wiseco 9:1 Compression Pistons
Eagle H-Beam Rods
Arp Headstuds
Arp Rod bolts
Z6 head with touched up ports, aftermarket retainers and springs, unknown turbo cam.
Skunk2 Pro Series Intake Manifold
Walboro 255 Fuel Pump
Golden Eagle Fuel Rail
RC 550 Injectors
ACT Pressure Plate with 6 Puck Sprung clutch
Blitz Bov
Tial Wastegate
Turbonetics T3/T4 50 Trim
Cast Iron Manifold
3" Exhaust straight pipe for ek hatchback...turbo back one piece no muffler
Oem Thickcore Radiator
MF Catchcan
P28 Chipped on Chrome Gold for 10lbs
Intercooler with piping for ek/eg
Z6 tranny, will come with axles and rear t bracket.
Obd2a dizzy
BAD: Motor has low compression in one of the cyclinders, something like 175 175 125 175, i will find out in a day or two if it is piston rings or a bent valve, if its just a bent valve then i could either replace the valve or switch valvetrain over to another used z6 head.
When motor was started it did not smoke whatsoever so im leaning towards bent valve.
No set price and no rush to sell since I could fix this and put it in my car.
Trying to see if I can sell complete as a whole package.
So full fully built turbo swap nothing missing or maybe will part kit with motor.
This is a strong setup good to 400whp. COMPLETE TURBO SWAP PACKAGE.
Old Jan 15, 2009 | 08:18 AM
Default Re: TW: SOHC sleeved motor and setup...
bump ttt!
Old Jan 15, 2009 | 11:23 AM
bump ttt
Old Jan 15, 2009 | 01:15 PM
Default Re: TW: SOHC fully built turbo swap
bump ttt
Old Jan 15, 2009 | 03:06 PM
dohcdelsol's Avatar
if you decided to part with the turbo kit lmk im interested
Old Jan 18, 2009 | 01:05 PM
Will sell for 2500 full swap to put into 96-00 civic including exhaust, stepdown harness and ecu and mounts....nothing missing, a legit gsr swap cost a little less then this but it wont get you into low 11s like this swap will. Nothing i mean nothing missing!
Old Jan 18, 2009 | 03:29 PM
Mr. Em1's Avatar
bump for my dude
Old Feb 20, 2009 | 10:09 AM
bump ttt!!!!
$2.5k
914 473 6959 ask for max!
Old Feb 20, 2009 | 10:22 AM
SL0-hatch's Avatar
if you find out what's wrong with the motor. let me know. would you be willing to trade for a complete gsr swap into ek with itr pistons?
Old Feb 20, 2009 | 12:52 PM
sorry no trades only sale. not trying to part out either unless price is right. only thing i know is the lower compression but when i started the motor it sounded alright. my number is 9144736959 if anyone is interested or s questions just text me
Old Feb 20, 2009 | 02:26 PM
CivicEX13's Avatar
well let me know if you want to get rid of the motor
Old Feb 21, 2009 | 08:40 AM
bump tttt
Old Feb 25, 2009 | 03:00 PM
bump ttttttt
motor has 160 compression across the board and less than 10% leakdown in all cyclinders...swap is ready to be run!!!
914 473 6959
Old Feb 26, 2009 | 09:07 AM
bump ttt!!!
jusholeum
Jan 26, 2011 10:38 PM
kinkyintegra
Feb 28, 2009 05:14 PM
11secK20
Nov 2, 2008 01:07 PM
M.A.R.C.
Oct 18, 2004 09:38 PM
