CEL 4 - CKP.. lost
Old Jan 14, 2009 | 02:56 PM
dump3deg6's Avatar
Default CEL 4 - CKP.. lost
I am throwing a code 4.. Which is Crankshaft Position Sensor. I made sure wiring was correct (going b16a into 4 door EF).
Ive read the sensor is inside the distributor so I changed it out with another one i had laying around. Still throwing the code. It runs, but throws the code..
Any ideas on how to get rid of it?
Old Jan 14, 2009 | 03:52 PM
89s1's Avatar
Default Re: CEL 4 - CKP.. lost
CYP (cylinder position sensor) is in dizzy. (it's a code 7, not code 4)
CKP (crank pos. sensor) is down near the crank on the block IIRC.
Old Jan 14, 2009 | 04:14 PM
dump3deg6's Avatar
4- Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 85-98
CKP Sensor (Crankshaft Position Sensor)
defective circuit or unplugged / defective sensor
its throwing a 4..
its a obd0 b16a motor btw
Old Jan 14, 2009 | 06:34 PM
efsedanfan's Avatar
dizzy
Old Jan 14, 2009 | 06:45 PM
apekd's Avatar
there are 2 white wires that go to your dizzy plug, switch them and it should work right
Old Jan 14, 2009 | 06:52 PM
93formula's Avatar
id do a continuity test first make sure the wires are going to the correct spot on the ecu...a buddy went thru three new dist before the shop he took it to discovered he wired his mpfi incorrectly and didnt get the wires in the correct pinouts..so one make sure you got proper continuity and make sure your in the right pinouts, this ofcourse is assuming you have just done a mpfi, also did you clear the code after swapping dist?
Old Jan 14, 2009 | 08:44 PM
89s1's Avatar
its throwing a 4..
Kewl. I stand corrected. I had read about the crank position sensor being down in the block, and had personally had the code 7 on my old obd0 b16a.
sorry for the confusion.
Old Jan 15, 2009 | 06:04 AM
rustbucketrex's Avatar
If you keep getting this code, check the connections at the ECU. The repinning loosens the female side of the connector (the tab that holds tight to the ECU pin) and if it does not make GOOD contact you will get a code 4. Check the wiring before buying new parts that you don't need.
Old Jan 16, 2009 | 02:27 PM
dump3deg6's Avatar
UPDATE
Runs, but above 3k RPM, it acts like it has launch control..
wtf
Old Jan 16, 2009 | 02:37 PM
93formula's Avatar
but did the code go away? can you confirm that you have checked all wiring at the ecu/continuity tests etc... any new codes?
Old Jan 16, 2009 | 02:38 PM
dump3deg6's Avatar
still continuing to throw code 4..
Checked all wiring, checked all connections on female side. Nice and snug
Old Jan 17, 2009 | 05:17 AM
b18atcrx's Avatar
its morethan likely a wiring problem. when i did dpfi to mpfi i used shorter pins in my ecu plug and i swore they were in tight and were making connection. i threw code 4 and had like a 4krev limiter. i redid my wiring about 5 times before i noticed that when i would plug the harness into the ecu those 2 pins i believe b10 and b12 (im not positive, just going off the top of my head) would barely get pushed out but enough to not make a connection thus causing my code 4. My best advice isto make sure you slow down and check it all again, once you get used to looking at something your used to looking at its real easy to over-look stuff.
Old Jan 17, 2009 | 05:42 AM
2point2's Avatar
Originally Posted by b18atcrx
pins
When everything looks right and something is still wrong it's almost always something to do with pins.
Old Jan 17, 2009 | 09:37 AM
ef_junky's Avatar
y ai had the same problem my harness was a mess from the guy before and he had them in the wrong place then it would only rev to like 3k we swapped a new dizzy out and nothin checked the wires and someone had bumped the plug wit there foot and bumped it loose we plugged it in and cleared the code and no more 3k rev limiter.....
Old Jan 17, 2009 | 12:01 PM
xci_ed6's Avatar
also if the wires are flipped you will have the problem. Plain and simple it is your wiring. You have tried good distributors and ECU's so it is your wiring. Grab your DVOM, schematic, and a beer, and just **** with it for awhile.
Old Jan 18, 2009 | 12:05 PM
dump3deg6's Avatar
yeah.. guess i'll have to mess with wiring again..
solfire
Aug 31, 2014 03:29 AM
blue_hatch
Feb 16, 2011 01:49 PM
edm_ef8
Jun 21, 2009 11:42 AM
criptic22
Jul 27, 2007 08:21 AM
