? for those with experience with titanium
Old Jan 14, 2009 | 02:14 PM
CVC9216's Avatar
Default ? for those with experience with titanium
I'm ordering titanium for my charge piping; is .020" wall CP2 titanium thick/strong enough for intercooler piping? My only other option is .050" 6AL-4V, which is more than double the price and then I would need two kinds of filler.
also, is it ok to fuse weld titanium, .020 and .035, maybe .050"?
Old Jan 14, 2009 | 03:08 PM
preludeserge's Avatar
Default Re: ? for those with experience with titanium
I've never worked with Ti, except welding a few coupons at school, but .020" seems kinda thin? Just out of curiosity though, what car/bike/boat is it going on? And why Ti? How much is a foot of Ti in that wall thickness (in whatever diameter that you're getting)? I don't mean to get the thread off topic, just curious.
Old Jan 14, 2009 | 03:54 PM
random_tuner's Avatar
Just curious, why not use Alum? Itll be a lot cheaper and with the right thickness, wll hold all the boost you can throw at it.
Titanium is very strong, but I would think you would need thicker than .020". Thats 1/50 of an inch.
Old Jan 14, 2009 | 05:28 PM
jspec - integra Ls's Avatar
ti is a waste of money for charge piping, what is the point of running titanium instead of aluminum. better save your money and get titanium for a different project like for instance redo your exhaust pipe. imo
Old Jan 14, 2009 | 06:03 PM
DESTROYER's Avatar
Ti is baller status. Do it!
Old Jan 14, 2009 | 06:11 PM
dave@passenger's Avatar
.020" will dent easily.
Old Jan 15, 2009 | 04:30 AM
Boostedld9's Avatar
what filler rod do you use on titanium? and what a quick setup for the machine, i have someone wanting me to weld up his muffler on a 750 but when i messed with just fusion welding it cracked around the weld
Old Jan 15, 2009 | 04:46 AM
ROTARY's Avatar
found this on the Miller website.
Titanium 101: Best GTA Welding Practices
Pretty colors are fine for titanium jewelry. However, blue, violet, green, grey and white colors indicate atmospheric contamination in a GTA welded titanium component. In critical applications, welds exhibiting such colors may suffer reduced strength and loss of ductility and could (or must) be rejected.
Responsible fabricators owe it to their customers and themselves to produce welds that meet standards such as those outlined in AWS D1.9, Structural Welding CodeTitanium, as well as their own high standards. This article provides an introduction to titanium, the GTA welding process, focuses on best practices and outlines common pitfalls. It is especially written with smaller companies in mind, as they perform the bulk of GTA welding.
About Titanium
Titanium and its alloys offer excellent corrosion resistance to acids, chlorides and salt; a wide continuous service temperature range, from liquid nitrogen (-322°F) to 1100°F; and the highest strength-to-weight ratio of any metal.
For example, the most widely used grade of titanium alloy, ASTM Grade 5 (Ti-6Al-4V), has a yield strength of 120,000 psi and a density of 282 lb/ft3. In comparison, ASTM A36 steel has a yield strength of 36,000 psi and a density of 487 lb/ft3, while 6061-T6 aluminum has a yield strength of 39,900 psi and density of 169 lb/ft3.
In short, titanium is about 45 percent lighter than steel, 60 percent heavier than aluminum and more than three times stronger than either of them. While expensive initially, titanium lowers life cycle costs because of its long service life and reduced (or non-existent) maintenance and repair costs. For example, the Navy replaced copper-nickel with titanium for seawater piping systems on its LDP-17 San Antonio Class of ships because it expects titanium to last the entire 40 to 50 year life of the ship.
In addition to military applications, other common uses for this light, strong and corrosion-resistant metal include those for aerospace, marine, chemical plants, process plants, power generation, oil and gas extraction, medical and sports.
Shielding Gas Is Critical
Titanium falls into a family of metals called reactive metals, which means that they have a strong affinity for oxygen. At room temperature, titanium reacts with oxygen to form titanium dioxide. This passive, impervious coating resists further interaction with the surrounding atmosphere, and it gives titanium its famous corrosion resistance. The oxide layer must be removed prior to welding because it melts at a much higher temperature than the base metal and because the oxide could enter the molten weld pool, create discontinuities and reduce weld integrity.
When heated, titanium becomes highly reactive and readily combines with oxygen, nitrogen, hydrogen and carbon to form oxides (titanium’s famous colors actually come from varying thickness of the oxide layer). Interstitial absorption of these oxides embrittles the weldment and may render the part useless. For these reasons, all parts of the heat-affected zone (HAZ) must be shielded from the atmosphere until the temperature drops below 800°F (note: experts disagree on the exact temperature, with recommendations ranging from 500°F to 1000°F. Use 800°F as a reasonable median unless procedures, standards or codes indicate otherwise).
One of the most common mistakes when welding titanium is not verifying the many variables that contribute to good shielding gas coverage prior to striking the first arc. Make it a practice to always weld on a test piece before beginning each “real” welding session. To ensure that gas purity meets your requirements, AWS recommends using analytical equipment to measure shielding gas purity prior to welding. Gas purity varies by application. Typical specifications require that the shielding gas (typically argon) be not less than 99.995 percent purity with not more than 5 to 20 ppm free oxygen and have a dew point better than –50 to –76°F.
Clean, Clean, Clean
Contamination from oil on your fingers, lubricants, cutting fluid, paint, dirt and many other substances also causes embrittlement, and it is a leading cause of weld failure. When working with titanium, follow the three Cs of welding: clean, clean, clean! Keep a clean work area, one free from dust, debris and excess air movement that could interfere with the shielding gas. Clean the base metal and bag parts not immediately welded, clean the filler rod and wear nitrile gloves when handling the filler rod and parts.
Welding Advice
ASTM International recognizes 31 grades of titanium. Different grades address the need for various combinations of mechanical properties, corrosion resistance, formability, ease of fabrication and weldability. While the various properties of these grades can be somewhat overwhelming (see the side bar story for brief explanation), the welding of titanium is relatively similar to other alloy metals.
The following images and advice demonstrate the basic best practices for welding titanium, expanding on the advice and information given above.
A standard GTA power source with high frequency arc starting, remote amperage control capabilities, a post-flow shielding gas timer and an output of at least 250 amps will work well for welding titanium. Set polarity to DCEN (straight polarity).
GTA torches can be air- or water-cooled, depending on equipment preference, as most welds will be short and at lower output levels. Water-cooled torches are smaller, more maneuverable and permit welding at higher amperages for extended periods, while air-cooled torches cost less. Notice the home-fabricated torch holder, which keeps the torch from falling on the floor.
For welding titanium use a 2%-ceriated tungsten sized to carry the required welding current: 1/16-in. or smaller for welding at <125 amps; 1/16- to 3/32-in. for 125 to 200 amps; and 3/32- or 1/8-in. for welding >200 amps. Use a gas lens to evenly distribute the gas and create a smooth gas flow, and use a cup with a diameter of at least 3/4- to 1-in. A larger cup will enable you to make a longer weld.
A trailing shield such as this one extends the length of the weldment compared to welding with a cup alone. It is constructed similarly to the purge blocks (See next caption. Commercial shields are also available). Notice that the electrode is extended longer than the normal, which is only advisable when using trailing shields or oversized cups, as they provide extended gas coverage. Normally, the electrode should extend just far enough to permit visibility and access to the joint, or about 1-1/2 times the diameter of the electrode.
To provide shielding gas coverage on the back and bottom sides of a joint, most facilities custom-fabricate their own purge blocks from porous copper sheet and stainless steel. The porous copper acts like a gas lens, evenly distributing the gas. To further smooth gas flow, the blocks are filled with stainless steel wool. Set the gas flow at 10 cfh for the purge blocks and trailing shield. Use 20 cfh for the torch.
When awkward joints preclude the use of standard purge blocks, welders fabricate shielding gas dams or chambers using stainless steel foil and fiberglass tape. To ensure purity, a rule of thumb is that the gas must flow long enough to exchange the gas inside the chamber 10 times prior to welding.
For demanding applications and where complex parts need to be welded, consider a vacuum-assisted welding chamber. This model utilizes a steel riser with glove ports and features a hemispherical, Plexiglas dome for viewing. After loading parts, a vacuum pump quickly removes the air, and the chamber is then filled with inert gas for welding.
This gas manifold system distributes shielding gas to the torch and all purge blocks using separate gas lines; notice the use of surgical grade tubing for quality purposes. Because moisture content rises as cylinder pressure drops, consider switching cylinders when the pressure reaches about 25bar.
First, select the appropriate filler rod to match the material grade (see Table 1 above). Then, use a lint-free cloth and acetone or methyl ethyl ketone (MEK) to clean the filler rod just prior to welding (after cleaning, store the acetone in a safe place prior to welding! Also, read the manufacturer’s safety precautions). To prevent the body’s natural oils from contaminating the filler rod or base metal, always wear nitrile gloves when handling titanium.
To prevent contaminants from entering the weld pool via the filler rod (notice the discoloration on the end of the rod), clip off the end of the filler rod before every use. Store the filler rods in an airtight container when not in use.
To break down the oxide layer prior to welding, use a die grinder with a carbide deburring tool to prep the edges of the joint. Do not use the tool for anything else except titanium. Follow mechanical cleaning by cleaning with a lint-free cloth and acetone or MEK.
A carbide file—again dedicated to titanium—may also be used to prepare the joint. Note the nitrile gloves, which are worn to prevent contamination. Simply wear welding gloves on over the nitrile gloves to prevent accidentally handling clean titanium with bare hands.
To hold the purge blocks in place while welding, consider a fixture/clamp arrangement like the one shown here. The holes in the welding table allow weldments and purge blocks to be clamped in a wide variety of positions.
Notice the variety of stainless steel blocks and shims used to position and balance the purge blocks. The holes in the welding table make it much easier to position the purge blocks, as it permits access for the gas lines from the bottom side.
Use a stainless steel brush—dedicated for this one purpose—to remove any impurities (e.g., light oxide coating) that may develop before continuing to weld. If welds require visual inspection for QA/QC purposes, omit this step. Note that the bead length is just about 1 in. Short beads minimize heat input and ensure that the bead won’t “outrun” its shielding gas coverage.
After turning off the arc, hold the torch in position so that the post-flow shielding gas continues to cool the weldment until its temperature drops below 800°F. Post-flow duration will vary by the mass of the weldment, size of the weld and total heat input (post-flow was set at 20 seconds for the weld shown here).
To keep interpass temperatures below the critical 800°F threshold, use an infrared temperature gauge. Also, weld at the lowest amperage level that still produces complete fusion. Finally, do not travel too quickly, as that is a leading cause of porosity and weld failure.
The front and bottom of the weld, which were properly shielded, show no evidence of contamination. To demonstrate the importance of shielding all sides of a weldment, the purge block was intentionally removed from the backside of this fillet weld and two welds approximately 3/4 – 1 in. were made.
The back of the weld indicates a completely unacceptable weld. Note the progressive degree of contamination, with the “chalky dust” showing extreme contamination. The weld cracked internally with an audible “tink” after cooling for about 90 seconds. Welds with such contamination may not be repaired: scrap the entire part or cut out and completely remove the contaminated section.
When adding filler rod, be sure the rod end stays within the shielding gas envelope. Use a dab technique to lower overall heat input (as opposed to leaving the rod end in the weld puddle, which increases the mass of metal and total heat necessary to metal it).
a) Discoloration must be removed prior to additional welding.
b) On the weld and in the HAZ up to 0.03 in. beyond the weld.
c) Violet, blue and green discoloration is rejectable if additional welding is to be performed. Blue and green discoloration is acceptable on finished welds but must be removed prior to subsequent processing.
Note: Discoloration comes in various shades, hues and tones.
Common Grades of Titanium
Titanium is divided in four classes: commercially pure (CP, or unalloyed), alpha, alpha-beta and beta. Note that many companies and experts treat CP and alpha alloys as one group. The “alpha” and “beta” refer to phases of the metal’s crystalline structure at various temperatures. Adding oxygen, iron, aluminum, vanadium and other elements to the alloy can precisely control the crystal structure, and hence the alloy’s properties.
The most common CP grade are ASTM Grades 1, 2, 3 and 4. They differ by the varying degrees of oxygen and iron content; greater amounts of these elements increase tensile strength and lower ductility. Grade 2 is the most widely used, notably in corrosion resist applications. CP Grades have good ductility, good elevated temperature strengths to 572°F and excellent weldability. They cost less than alloyed grades, but have a relatively low tensile strength, such as 70,000 to 90,000 psi for Grade 2.
Grade 5 (Ti-6Al-4V), an alpha-beta, is the most widely used of any grade of titanium (50 to 70 percent of all uses, according various sources). The addition of aluminum and vanadium increases tensile strength to 120,000 psi and service temperature up to 752°F, but it also makes Grade 5 less formable and slightly harder to weld than Grade 2. It is used for a range of applications in the aerospace, marine, power generation and offshore industries.
Grade 23 is similar to Grade 5, but features reduced of oxygen content that improves ductility and fracture toughness with a just a slight loss of strength. Grade 9 strengths fall between Grade 4 and Grade 5, so it is sometimes referred to as a “half 6-4.” Grade 9 can be used at higher temperatures than Grade 4, offers 20 to 50 percent higher strength than commercially pure gradesS and is more formable and weldable than Grade 5.
Acknowledgments
The author would like to acknowledge the significant contributions to this article made by two people. Geoff Ekblaw has more than 40 years of experience (and the patience to pose for the photos in this article). He is the senior welder at Woods Hole Oceanographic Institution (WHOI, www.whoi.edu). Woods Hole Oceanographic Institution is a private, independent organization in Falmouth, Mass., dedicated to marine research, engineering, and higher education. Established in 1930 on a recommendation from the National Academy of Sciences, its primary mission is to understand the oceans and their interaction with the Earth as a whole, and to communicate a basic understanding of the ocean's role in the changing global environment. WHOI is world-renowned for its deep-sea submersible vehicle Alvin. Alvin makes extensive use of titanium and is most famous for its use in exploring the wreck of the Titanic.
Jody Collier is a senior certified welding inspector (SCWI) and Instructor/Developer, Welding Training/Certification with Delta Air Lines Technical Operations Center in Atlanta (Delta TechOps; 866-MRO-Delta or TechSales.Delta@delta.com). Delta TechOps is the largest airline MRO in North America, earning more than $312 million in revenue in 2006. In addition to providing maintenance and engineering support for Delta's fleet of 440 aircraft, Delta TechOps serves more than 100 aviation and airline customers from around the world, specializing in high-skill work like engines, components, base and line maintenance. Delta TechOps employs more than 6,500 maintenance professionals and is one of the most experienced MRO providers in the world with more than seven decades of aviation expertise.
Works Consulted
American Welding Society (2007), Structural Welding Code, Titanium (AWS D1.9), https://www.awspubs.com/
Titanium Metals Corporation (1997), Titanium Design and Fabrication Handbook for Industrial Applications, http://www.timet.com/pdfs/ti-handbook.pdf
TWI (The World Centre for Materials Joining Technology) and The Titanium Information Group (1999), Welding Titanium, A Designers and Users Handbook, http://www.twi.co.uk/j32k/protected/pdfs/bpweldti.pdf [Visitors must register to download this file]
Donachie, Jr., Matthew (2000), Titanium, A Technical Guide, ASM International, http://asmcommunity.asminternational.org/portal/site/asm/
Kobelco, http://www.kobelco.co.jp/english/titan/files/details.pdf
Old Jan 15, 2009 | 06:32 AM
shortyz21's Avatar
wow that was a good read. thumbs up
Old Jan 15, 2009 | 06:44 AM
CVC9216's Avatar
I knew I was going to get a bunch of people telling me not to waste my time. I'm doing titanium because it looks cool, and I've never welded it so I want to try it out. I've read the above article, but it doesn't answer my questions. I know .049 wall stainless is plenty strong for IC piping and since ti is 3x stronger, seems to me that .020 would be sufficient. Vibrant aluminum bends are really really soft but I've used them plenty of times and they do the job. If nobody can tell me they've tried .020 and it's too thin I'm going to try it out and I'll let you guys know what happens. here's a crappy pic of my engine bay. anther reason I want to do ti is b/c the cold side is pretty tight and will need to be pie cut anyway
the .050 is around $4/in and the .020 is under $2/in.
I believe you use the same filler as grade ti you are welding. the article above should answer the rest of your questions.
Old Jan 15, 2009 | 07:04 AM
silly sohc's Avatar
Welding .5mm (.020") wall in anything is a long process. All of your joints cannot have any mistakes what so ever. .5mm is the thickness of most F1 headers for qualifying, they last one w/e for a weeks worth of work of one man for 4cyl's. Obviously you won't use that sort of heat, but in perspective its over kill in means of prep and material... .9mm is more common, and 10 fold more forgiving... we haven't seen your weld ability yet, but I would suggest an hours worth of practice on .020". Your welder may not be dialed in accurately on the low amperage settings also.
Old Jan 15, 2009 | 08:01 AM
CVC9216's Avatar
I'm not a pro by any means but I'm confident that I can weld it. I need three diameters, 2.75, 3, and 4". The 3 and 4" I'm getting in .035" but they only have the 2.75 in .020 wall. I'll only need 2-3 welds probably on the 2.75 but If I can't weld it or it's too soft, I'll just use all .035 3". I'm going to be using an older syncrowave 300 but I can also use a dynasty 200dx if that would be better. I'll fit up all the pipes and then practice on the scrap before I weld everything. Is one of these cups good enough for shielding or should I build/buy a trailing shield?
http://www.arc-zone.com/index.php?ma...oducts_id=4671
Old Jan 15, 2009 | 09:21 AM
92TypeR's Avatar
FSAE
Actually, steel is much stronger than Ti.
Materal - Density - Ultimate Tensile Strength - Elongation at Break - Melting temp
SS 304 - 0.286 lbs per cubic inch - 78 ksi - 67% - 2600 F
Commercial Grade Titanium Alloy - 0.163 lbs per cubic inch - 63 ksi - 18% - 3000 F
Digesting this information, we can see that 304 SS is about 20% stronger than Ti given the same size pipe/tube/structure/widget. But Ti is about 45% less dense, so its specific strength is very good.
The percent elongation at break shows us that steel will deform (bend/dent) quite a bit before failure, where Ti is more brittle.
However, aluminum is the BEST choice if you are looking for the lightest possible charge piping.
6000 Series aluminum alloy - 0.097 lbs per cubic inch - 55 ksi - 35% - 1150 F
Its density is far less than Ti, which is why you will commonly see Aluminum alloys as the principal material in most tubing, piping, and structural components where it meets strength and temperature requirements. Charge pipes would easily fit in this category. If you are after the lightest material for the job, aluminum is the best choice unless you move into composites or thermoplastics.
If you want Ti for the bling factor, you will need to use a heat gun to get the rainbow color effect. Ti does not discolor like you see in bling bling aftermarket parts by simple welding. Plus Ti requires some tricky welding setups as shown in previous posts. Al is much easier to deal with, and is cheaper!
Old Jan 16, 2009 | 09:10 AM
CVC9216's Avatar
thanks for the info, glad I didn't waste my money. I didn't realize CP titanium was so soft. I think I'll be OK if I use the .035 wall 3" tubing all the way around. I found some .035 and .049 wall stainless I may just use that instead. The reason I don't want to use aluminum is because I hate the way pie cut aluminum looks and I have a very tight space to work with on the cold side. Where did you find a 55ksi value for the aluminum? I looked it up, for 6061-0 uts is only 18ksi
Do you have experience welding titanium? Is it ok to fuse .035 thickness ti for a IC piping application or do I need filler?
Old Jan 16, 2009 | 12:56 PM
92TypeR's Avatar
FSAE
AA6070 with T6 heat temper has a 55ksi UTS. This is the highest of all structural 6000 series AA's.
6061, which you would most commonly purchase in either untreated or T6 temper has a UTS between 13 and 25 ksi, depending on manufacturer.
I have not personally welded Ti. My chassis handbook right here says use filler for titanium with wall thickness thicker than 0.010 inch.
Old Jan 16, 2009 | 07:27 PM
damnraz's Avatar
Don't make everything too complicated. I believe .020 wall CP-TI is strong enough, it does NOT dent easily as stainless or aluminum. I've welded Titanium for over 4 years and I can get you setup to get you going.
Titanium puddles are very easy to see, they're red hot.
Filler is AMS 4951, make sure you add your filler in front of the puddle if you're pulling towards you, right on the edge. If your torch angle isn't right it'll just ball up or your wire will stick on the parent material.
Backpurge is absolutely necessary. If you do not backpurge the inside of your tube, your weld will be very brittle.
If not welding a tube, make sure you make get a backing trailer for fillets on plates and etc..
Cup size: 12
Tungsten: 1/16 is what I prefer. 2%, Zirconiated whatever.
Gas lense is a must
Amperage: 40-60 amps. Make sure your fit-up is damn near perfect or you will be blowing holes left and right. Tack any points necessary. And if welding near a bend radius check the OD of the straight because it might be undersized due to how mandrel bending works.
Thats it.
Follow the HAZ chart as posted above. Strawish to no color is what you want. If it's Blue it'll be fine just don't let it get to that gray flaky color.
Weld beld should be small, it doesn't take much to penetrate through CPTI, do not bevel the edges.
Follow my instructions and you'll do great
Old Jan 19, 2009 | 05:36 PM
CVC9216's Avatar
ok glad someone with experience chimed in, that's what I wanted to hear. I'm going to order the piping tomorrow and I'll update with pics when I get it all done. It will be backpurged and I just picked up a huge 1" gas lens from a friend. I can't wait to try it out!
Old Jan 19, 2009 | 06:57 PM
40-60 amps is WAY WAY too much heat for .020" Ti. Try around 20amps. Filler diameter should be around .020", tungsten diameter will be best with .020"-.040". The large gas lense is what you want for sure.
Old Jan 23, 2009 | 05:44 PM
9bells's Avatar
OG Fabricator
I would agree that 40-60 amps is a bit much. Maybe on a positioner, maybe.
I would start with 20 set as your max, yes. If it still seems hot, set your 200dx pulse to 1.5 pulses/second, and use that to time and cool the puddle.
As with any welding with TIG, I recommend the smallest filler possible to achieve a very high melting rate and very tight ripples in the puddle.
I posted a few pics of some of my welds on 6al/4v, and I used an .045" filler rod on 1/16" plate. I also used a 1/16" filler rod on the 1/8" plate. They are far from perfect, but they get the idea across on the ripples and the color.
http://i131.photobucket.com/albums/p...s/IMG_5519.jpg
http://i131.photobucket.com/albums/p...s/IMG_5524.jpg
http://i131.photobucket.com/albums/p...s/IMG_5620.jpg
http://i131.photobucket.com/albums/p...s/IMG_5618.jpg
Old Jan 23, 2009 | 07:08 PM
Teglove2's Avatar
I am certified Ti welder and I can tell you it must BE PERFECT in order to weld properly...I would def have someone who is experienced do it for you. Must be FULLY backpurged. Its not like ss where if its not perfect it wont really matter. You need a very very long postflow and perfectly steady hands. Any flucuation in hand movement and Itll contaminate. Just like the article says HUGE cup, 1/16" tungsten always clean, and def no dirty filler rod ends. The puddle should be white/silver tint. The .020" is a lil on the thin side if you ask me but it will work if done right. Yes AMS 4951 is the correct filler rod, use it everyday
Good luck man sounds cool
Old Jan 23, 2009 | 08:20 PM
I'd agree with everything 9bells said except for the 1.5 pulse per second... Low speed pulsing is really only good for welding non critical parts. If you want to use pulse I'd recommend going high speed (400+pps).
Old Jan 28, 2009 | 06:47 PM
damnraz's Avatar
Actually .020 and .028 wall Ti is what I weld almost everyday for over 4+ years. 40-60amps is fine, just make sure your fitup is money. Sure you can use 20amps and push your foot to the floor but why? It's better to learn foot control. Pulsing titanium in a fillet weld position, I set the pulse at 3 pulses per second. I lay the wire down at a 45 degree angle with a slight bend to it and run my torch over the wire. It'll take some practice and it's more of an advanced technique. Forget pulsing for now. Weld it normally.
Old Feb 5, 2009 | 11:04 AM
CVC9216's Avatar
Originally Posted by damnraz
Filler is AMS 4951
bump for one more quick question, AMS 4951 is the correct filler for CP titanium? I'm guessing it won't work for grade 5? Also, I use ceriated tungsten for everything, any reason I should use another?
Unfortunately I'm a bit strapped right now so I haven't ordered the titanium yet, but hopefully soon. Wish I had some scraps to play around with in the mean time
Old Feb 7, 2009 | 02:57 PM
damnraz's Avatar
6AL4V I use AMS 4954, you can weld 3-2.5 with it also. Even though you still can weld with 4951 but according to specifications here in aerospace we're not allowed to use any other wire other than AMS 4954. Ceriated tungsten works fine. It's supposed to be an upgrade to 2% Thoriated without the radiation issue. I prefer Lanthanated (gold) due to the fact it creates a narrower arc and has great arc starting capabilities. Also, even if you dip your tungsten a few times it'll still maintain a sharp point for a while.
Old Mar 15, 2009 | 04:51 PM
FPV_GTp's Avatar
Nice piece of information ROTARY good to see people share info
cheers
