Comptech Titanium Front Upper Tie Bar, Rapfix II & Splash Hub, K-Series Motor Parts
Complete K24A1 head, approx. 40k mi. *SOLD*
Works Bell Rapfix II quick release (black) with with Works Bell Splash short hub for 96-00 Civic *SOLD*
Comptech titanium front upper strut bar for 99-00 Civic *SOLD*
Spoon N1 Suspension for EK9. Roughly 4000 miles on the set. Fronts are 14kg and the rears 12kg. 5 step damper adjustment. *SOLD*
Comptech Icebox, complete with a sealed UNI service kit extra C.A.R.B. sticker and rubber breather tube adapters *SOLD*
Comptech rear sway/tie bar combo *SOLD*
D16y8 Head, freshly resurfaced and tested from the machine shop *SOLD*
- Z3 vtec solenoid, new but no package
- Z3 Crank pulley, very light use
- Complete Z3 head
- RBC Intake manifold
- Z3 oil cooler, very light use
- RBC water pump with oil cooler joint, joint o-ring, and pump mounting bolts
- RBC water passage housing and o-ring
- Z3 crank pulley, bolt, & key
- Thermostat assembly, thermostat case, seal to bolt case to water passage, and all bolts for both.
- Z3 timing chain tensioner and bolts
- Timing chain cover bolts
- Valve Cover and new gasket
- Coil packs, used. *ALL SOLD*
Thanks for looking!
- Complete Z3 head
Thanks for looking!
Excellent condition, no leaks (functionally speaking). Visually, you can tell these have seen the road, and look like any undercar component would after use. I didn't clean them up very well for their photo shoot.
pm'd
pm'd
any way for those spoon dampers to fit a dc2, pm me?
You'd spend the same amount on custom made aluminum lca's as it would cost you for this suspension, maybe even more. But if I were going to do it, thats the way I'd go.
Thanks
To all those who pm'd me about the rear swaybar, it looks like the deal will go through to GSR_Hatch8 (pending funds), he was the first to contact me about it. Thanks to the rest of you for your interest!
