GSR HIGH CR: CHANGEOVER. 2000.00 (o miles brand new)
2000.00 TAKES EVERYTHING
I am selling this because ive got 4 other cars and no garage space for this project.
engine came from a 94 gsr sedan. Its been professionally disassembled and hot tanked and cleaned, then bored to 82mm with a .0010 piston to wall clearance. The crank is perfect and shows no wear. The rest of the items are either brand new, or in excelent condition...
Starting from the deck down.
-Un decked, un milled orig gsr deck height undamaged 94 block. bored to 82 just for slightly more displacement and because i already had the pistons, not damaged and bored out to cover damage.
-factory head bolts
-brand new oem headgasket.
-oil oriface pin
-pr3 os 82mm pistons with oem rings (pressed onto 01 gsr rods 6k miles old!)
-acl duraglide bearings (ones that are same spec as all greens oem honda bearings.
-stock oil squirters
-stock b18c1 crank (NO TURNED GARBAGE EITHER)
-Brand new oem itr oil pump
-Brand new oem itr water pump
-brand new oem timing belt
-brand new oem master bottom end gasket set
- all plastic timing covers uncut(NEED TYPE R STYLE LOWER COVER)
-factory crank pulley from 94 gsr
- factory oil pan, not damaged, factory windage tray, factory pickup
-Factory dip stick
-factory mounts (rear mount bracket, timing belt mount (no torque mounts, no trans mount)
- alternator (worked fine, looks older)
-newer starter
-oem gsr harness
-intermediate shaft
-Knock sensor, coolant temp sensor, freezeout plugs, pcv catch box and hosing
-Rear water pipe and thermostat housing.
-stock gsr flywheel
-stock gsr clutch
-STOCK 94 GSR trans (no grinds, no bearing noises no surprises)
-gsr shift linkage
-b&m ripper shifter
-s2000 shift ****
-passanger side axle
-p28 ecu
-p72 ecu
-another spare gsr harness
-gsr radiator
-gsr hoses
-gsr fan
-gsr power steering pump
-gsr mounts
-type r mounts
-coolant
-even a fuggin pepsi and a hotdog if you need a snack after your road trip.
these are the pictures of the parts. more to add....
shorty...
fresh and ready for some 16 year old rb to over rev it after christmas!
temp valvecover/timing covers. new ones en route
just updated pictures. more comes with.
All this swap needs to be 100% COMPLETE IS
-distributor (120.00)
-drivers side axle (50.00)
-98+ type r lower timing cover(gsr one will not clear brand new type r oil pump) (30.00)
200 DOLLARS WORTH OF STUFF MISSING. BRAND NEW GSR ENGINE PROFESSIONALLY ASSEMBLED 0 MILES 0 BEATINGS 0 PROBLEMS.
A USED ONE WITH SOME LIAR TELLING YOU IT HAS 35K IS 2500.00
NO BAD CHECKS
NO TRADES
CASH TALKS
ill give you EVERY HONDA PART I HAVE FOR THIS. THROTTLE CABLES, P28, P72, GSR RADIATOR, HOSES, FAN, COOLANT, EVERYFUGGIN THING!!!......just take this out of my face. i want to sell it to buy parts for my other car and its sitting wrapped as a longblock in my climate controled basement. the trans, flywheel, and ecu/harness stuff is seperated so someone can take it in their car.
THIS ENGINE IS 11.58530944751803 :1 COMPRESSION
IVE HAD 234234 PM'S ABOUT THIS. ALL FLAKES. ALL WANTING ME TO TAKE TONS OF PICTURES, OR PUT IT TOGETHER, OR DO THIS OR THAT.. HERES WHAT IT IS. ITS BRAND NEW PARTS, PROFESSIONALLY PUT TOGETHER, PRICE IS FIRM. and giving it away at that price. NO WAY COULD I EVVVVVVER GET ANOTHER ONE OF THESE WHEN I WANT IT FOR THIS CHEAP FOR AS MUCH AS I AM GIVING YOU.
Sorry to sound so stern, i just am fed up with dealing with teenagers on a daily basis who DO NOT read the post.
ADULT OWNED, ADULT DEAL. NOT INTERESTED IN DEALING WITH SHIPPING COSTS. YOU WANT IT SHIPPED, WIRE TRANSFER THE MONEY, WHEN THE BANK CERTIFIES THE MONEY HAS CLEARED, ILL HAVE IT FREIGHT SHIPPED OUT OF MY BUSINESS ADDY AT YOUR COST.
hybridboy93@hotmail.com is the FASTEST WAY to get in touch with me. Often times i cant check on here throughout the day at work.
anyone OG on Hybrids.jp will vouch for me
I am an original member of hondatech. my user name was colt45.5, my x girlfriend just changed the password and email.
Dunno if I should vouch for him, he knows where I lived
Wait, I can vouch for him....I moved
BTW, those pistons ROCK!
c'mon people, this is too cheap for what you're getting, someone is going to get a damn good deal. Brand new high CR b18c for $2000? Redonkulous
there you have it.. the patrick swayze of riceboys has spoken..
**** that old swayze tho, you need the jim cunningham pedo swayze from donnie darko.. haha
some dude may buy the longblock this weekend.. Id love to sell this as a complete swap.. but i really am sick of sitting on it.
STILL FOR SALE.. BUY IT NOW
IM NOT JOKING, I WILL GIVE YOU ALL these honda parts. i have NO USE for them once this is sold.
-newer 51r battery
- aem power steering pulley on power steering pump.
-gsr jg edelbrock flange for intake manifold to make your own itb's for p72, ****in anything i have take it. 2000.00
-countless little nick nacks..
Need room for small block chevy parts, rear ends, and nitrous bottles.
-newer 51r battery
r1de23
Jul 15, 2009 06:30 PM
civicking99
Dec 12, 2008 05:24 AM
incognito E46
Apr 2, 2008 09:56 PM
SLOW EF8
Jan 15, 2006 04:54 PM
