Odyssey automatic sliding door
The left side of my Odyssey automatic sliding door doesnt work, Its a 2001 Odyssey.
I checked the fuses and they are all good, the left side doesnt work but the other side does.
i have the same problem, i also checked the fuses. I going to start be changing the switch to see if that does anything. You can aslo check here http://www.odyclub.com/
on the pass side kick panel there is a fuse labled back up..its a 7.5 amp fuse i believe. pull that fuse for about 30 seconds and reinstall it..that will reset the computer for the sliding doors and both doors will work again. also one this to make sure is that all door seals are cleaned, honda make a rubber care product that works great. this will prevent your doors from going into safety mode.
Pull off the b-pillar trim on both sides and make sure that ground is good. If you think it might be bad just install a star washer between the wire and body (scrape off any paint to bare metal). There is a service bulletin for this.
slo95cx
Aug 7, 2004 08:47 AM
