obd0 to obd1 distributor sub harness
Old Jan 14, 2009 | 09:09 AM
efjones9's Avatar
Default obd0 to obd1 distributor sub harness
i am trying to make my own obd0 to obd 1 sub harness i guess is what u can call it. and ive done alot of research, i just kant find solid discriptions on how to do this. can any1 help? thanx n advance
Old Jan 14, 2009 | 09:24 AM
grand champ's Avatar
Default Re: obd0 to obd1 distributor sub harness
I did a couple last year, as far as i can remember its just matching up wire colors....
Old Jan 14, 2009 | 09:33 AM
efjones9's Avatar
did u use the mpfi female dizzy plug
Old Jan 14, 2009 | 06:22 PM
kylesmith3251's Avatar
i also just got a b18a1 thats obd0 my ecu in my car is obd1 i was wanting to know about this sub harness and stuff what is it? will it make the obd0 dizzy run with the obd1 ecu?
Old Jan 14, 2009 | 11:00 PM
crx_si-r's Avatar
they are pretty simple to make, i make and sell them. check out my sig.
Old Jan 14, 2009 | 11:04 PM
D16SiHatch's Avatar
this will help
http://hondaswap.com/hybrid-ed-ef-da...adapter-73435/
Old Jan 15, 2009 | 06:35 AM
stankcrx's Avatar
seriously just call rywire
Old Jan 15, 2009 | 06:53 AM
jlicrx's Avatar
Rywire no longer sells it separate, only as part of package
Old Jan 15, 2009 | 07:57 AM
01-0041's Avatar
It's not that hard to re-pin...
I'm using an OBDII with OBD0 Plugs!
Old Jan 15, 2009 | 02:52 PM
efjones9's Avatar
thanx d16aihatch dont wana pay some 1 to do work that i could do
im on a low budget lol
Old Jan 15, 2009 | 04:44 PM
Icon2 Re: obd0 to obd1 distributor sub harness
so changing the wires up will make it so i can run obd0 distributor with my ecu which is obd1??????????
Old Jan 15, 2009 | 05:57 PM
crx_si-r's Avatar
no, you CANNOT run an obd0 distributor with an obd1 ecu. All parts must be obd1 if that is the ecu you are going to be running
Old Jan 15, 2009 | 06:02 PM
D16SiHatch's Avatar
negatory. the point of making the coversion harness is so on an originally obd0 car you can use an obd1 distributor with an obd1 ecu. obviously you would need the obd0-1 ecu harness/jumper as well.
ninja edit: dayum! beat me to it
Old Jan 15, 2009 | 06:32 PM
so what would be better getting an obd1 distributor or getting a p72 obd0 ecu?
Old Jan 15, 2009 | 07:14 PM
efjones9's Avatar
ive read that obd 1 is easier to tune and get better results with a p28 ecu
Old Jan 15, 2009 | 07:24 PM
ok cool do you know where i can pick up a obd1 distributor for a b18a for a good price
Old Jan 15, 2009 | 07:45 PM
D16SiHatch's Avatar
junkyard? ebay? craigslist?
also, there is no such thing as an obd0 p72.
The oldest ecu you'd be able to find which was designed for a gsr, is the obd1 p61 for the b17a1 from the 92-93 gsr. since you are going to have to go to obd1 anyway you might as well just get a 94-95 obd1 p72.
ninja edit: wait a minute. why are you looking for a gsr ecu, but a dizzy for a b18a ? if you really meant that you need an obd0 b18a ecu, then just get a pr4 and keep everything obd0. oh and quit threadjackin. took me a min to realize you weren't the OP lol.
Old Jan 15, 2009 | 07:46 PM
efjones9's Avatar
junkyard maybe. start there. or craigslist
Old Jan 15, 2009 | 09:02 PM
im looking on ebay at pr4 ecu's what the diffrence of the pr4-A02 and the pr4-A10 and all that what should look at getting
Old Jan 15, 2009 | 10:25 PM
D16SiHatch's Avatar
maybe it designates auto or manual? or perhaps whether its obd0 or obd1? i'm not really sure. just make sure whatever one you get states that it is for the obd and trans type you have.
Old Jan 16, 2009 | 07:10 AM
Thanks for the help man
Old Jan 16, 2009 | 01:29 PM
stankcrx's Avatar
you can use a jdm pw0 its obd0 and will run dohc vtec its off my b16 not sure if it will correctly run a gsr .. but i have a obd1 p28 for sale if you want one
Old Jan 17, 2009 | 04:09 PM
efjones9's Avatar
how much?? with shipping to CA
Old Jan 17, 2009 | 04:20 PM
D16SiHatch's Avatar
an obd0 pw0 does not have control for iab's (secondary butterflies) and will cause you to lose mid-range power. if you spent the money to get a gsr you might as well spend a little more for the correct ecu.
SlowB20z
Sep 3, 2012 06:30 PM
white92teg
Feb 12, 2010 01:09 PM
bayron
May 14, 2009 05:39 PM
ant$missShift
Mar 12, 2005 09:06 AM
Norcalstoppy
Jul 13, 2002 08:02 AM
