battery drain while car is off x.x please help
Old Jan 14, 2009 | 09:08 AM
gsilnc's Avatar
Default battery drain while car is off x.x please help
ok, got a drain, 90 da, car off... test light on, im hoping some electronic genious will help me.
there is a backfeed through the radio i think. i unplug the radio and the light stays on, plug the radio and turn the keys all the way and the light goes off... then turn the keys off and the light stays off.... but! turn them on and off and the light's back!
the fuse for the radio makes no diff. and the fuse for the clock, cig lighter, and dome light is out.... when i turn my dome light off(doesnt work anyway) the clock comes on... turn on... and clock comes on... idk if this has anything to do with it though.
basically i have no dea what it is... the alternater is new and so is the battery... which holds its charge.
im stumped :/
Old Jan 14, 2009 | 06:10 PM
egNYC's Avatar
Default Re: battery drain while car is off x.x please help
are you using a multimeter? If not use one with the meter on Amp and hooked it up to the battery and see what the reading is. The amperage should be pretty low with the key off. Then you can pull fuse as you check the reading when the read drops down then you found fuse that powers the draw and can look at the schematics and trace back to what it power.
Which light stays on when you unplug radio? does the car start after sitting overnight?
Old Jan 16, 2009 | 04:16 AM
gsilnc's Avatar
no it goes dead.... but i think i may have found it cause... i connected the battery last light.. it was hella cold and the fan came on... u know skratch my knoggin like "uhh.. my cars been sitting off for days and the fan comes on?"
so im thinking its one of the two switches that control the fan... but imma try that method u told me w a multimeter
Shelby Le
Nov 2, 2010 02:26 PM
jdmunzip
12
Sep 4, 2006 08:47 PM
justseeingifitistaken
13
Jul 19, 2006 08:39 PM
gooproduct
Dec 17, 2005 04:58 PM
10KrpmS2K
Honda S2000
Aug 11, 2005 07:36 PM
