1999 honda civic dx Ls swapped built gsr trans no rust OHIO
Old Jan 14, 2009 | 12:28 AM
dewulf92's Avatar
Default 1999 honda civic dx Ls swapped built gsr trans no rust OHIO
here's the story. i bought this car about 4 months ago not running. the car had a hacked wiring harness, engine and dash. so i bought both harness , pulled the dash out. i replaced the dash harness and the dash needs installed (very easy about 8 screws and 3 bolts) and the engine harness installed. both are included. ther is no rust on the car what so ever. the car is a 1999 Honda civic DX 4 door. green exterior tan interior. the engine is from a 99 Acura Integra LS B18B1. arp head studs. arp rob bolts. cometic head gasket.fidanza clutch/flywheel kit. gsr trans mith a quaife LSD gear speed carbon coated sycrnos 1-5 and sleeve kit 2-4. DC 4-1 Header. no cat. custom 2 3/4" exhaust with apex'i N1 tip thats comes out at an angle. it's is lowered on max speed coil-overs. also has solid insterts. the previous owner planned on boosting this but ran out of funds thats the reason for all the work done to the car. I also did a wire tuck tuck. tan integra seats to match the interior. the only thing left to do is install the engine harness. no rust, 1 very small dent above rear driver door maybe 1in" by 2 in", pain is perfect. head lights are crystal clear. the motor runs flawless. and transmission is also shifts like butter. a 99/00 civic si engine harness will be included along with a stock dx harness.
For $3500 you can have the car how it is. for $2000 u can have the rolling chassis without engine, transmission, axles, shift linkage.
trades....i will entertain almost any trades. mainly looking for hondas.just let me know. the car has a clean ohio title with 82k on the chassis
Old Jan 14, 2009 | 07:11 AM
xachary82's Avatar
Default Re: 1999 honda civic dx Ls swapped built gsr trans no rust OHIO
interested in a caddy+ cash on your side?
Old Jan 14, 2009 | 04:19 PM
dewulf92's Avatar
no thanks, i am currently laid off, plus i just bought a 07 cts. bump
Old Jan 14, 2009 | 08:50 PM
95gsrEG's Avatar
trade for a lsvtec del sol? shoot me a txt i want this...8149348002
Old Jan 16, 2009 | 06:33 AM
dewulf92's Avatar
Sold!!
hondacurious
Apr 21, 2014 06:15 AM
oehawks3
Jul 11, 2012 07:36 PM
maritime_ef
Oct 26, 2011 09:05 PM
HatchBox
Jan 13, 2006 10:37 AM
HatchBox
Northeast (Sales)
Jan 12, 2006 08:18 PM
