saturated injectors with p13?
Hello guys, I'm doing a swap into my civic its an h22 into em1. I was wondering if I can use the p13 ecu with with the 97-01 prelude injectors. Those are saturated 280cc injectors. The p13 that I have is from t he obd1 92-96 prelude which originally was for peak hold injectors which need resistor box. . Do i need a resistor box or no? Any mod that I have to do or do i just plug and play. thanks
you should be able to run the saturated injectors just fine. People use p28 ecu's with peak and hold injectors so the concept is forward and reverse compatible....
