timing belt and dizzy question
Old Jan 13, 2009 | 09:27 PM
0ne-Cam's Avatar
Default timing belt and dizzy question
is there a thread on how to time the d series corectly? my timing belt was put on correctly, cam gear showing 'up' and aligned with the head, the crank pulley is at the TDC, meaning 0 degrees? how do i find out if my dizzy is firing correctly on cylinder #1?
ive searched around but couldnt find the right thread on this.
Old Jan 13, 2009 | 10:03 PM
jdm_civicef_9's Avatar
Default Re: timing belt and dizzy question
i would just put a timing gun and call it a day. are you having a firing order problem?
Old Jan 13, 2009 | 10:47 PM
0ne-Cam's Avatar
what do you mean put a timing gun? firing order is 1-3-4-2, if im not mistaken. engine just cranks but it doesnt start
Old Jan 13, 2009 | 10:58 PM
93formula's Avatar
make sure you got your ignition wires in the correct locations...
https://honda-tech.com/forums/showth...t=firing+order
Old Jan 14, 2009 | 12:17 AM
if the car was starting then u could shoot the timing. Yeah that's the right order, my bad didn't know the car wasn't starting. You could take out the #1 spark plug wire at the spark plug and Stick a screwdriver in there hold it to any grounded metel and crank the car to see if your getting spark from it. When is the last time the car ran?
Old Jan 14, 2009 | 12:19 PM
0ne-Cam's Avatar
the engine is vitara built so it never started, what about the dizzy not firing at the proper time, would that be the timing issue or?
Old Jan 15, 2009 | 09:14 PM
um not unless the rotor is loose it should be fine, did u get a chance to check if ur getting spark?
Old Jan 15, 2009 | 10:55 PM
88efZ6's Avatar
Bring the motor to top dead center and pull the cap off of your dizzy and make sure it is pointing at where you have the wire for the #1 cylinder. It could be 180 degrees out or you could have the wires one spot off or something dumb like that. I had the same problem just the other night with a friends car after we put his motor in
Old Jan 17, 2009 | 08:34 AM
SLURS's Avatar
hell yea thanks for posting this i was having tha same trouble!
Old Jan 17, 2009 | 11:21 PM
0ne-Cam's Avatar
no i didnt get a chance to see if im getting spark. it was -35F outside here in iowa last 3 days and when u dont have a heated garage it can be a pain
buddy190
Apr 24, 2009 02:34 PM
nighttrain33
Mar 23, 2008 01:38 PM
dopefeen
Apr 25, 2007 04:59 PM
Fighterinsnatch
Jul 11, 2006 05:36 PM
BB6racer
Jun 16, 2005 12:04 PM
