1996 accord valve adjustment and voltage problem
please help me get the valve adjustment procedure for my F22 engine the link in FAQ is dead.
I'm going to guess that it is a SOHC F22B2, only because you didn't mention it having VTEC on the valve cover. Does it have VTEC written across it? If it does then it's an F22B1 if it doesn't than it's an F22B2 Non VTEC, both are Single Over Head Camshaft (SOHC) interference engines.
Adjusting the valves may give you back some pop but I would put money on it being more of a full tune up that it requires. Even if it hasn't been driven that much the timing belts and other regular maintenance still needs to be carried out. Check your owners manual. I'm pretty sure your probably up for a full tune-up including timing and balance shaft belts and all the rest of the goodies. you can adjust the valves while your doing the timing belts.
I want to adjust my valves this weekend since ive done everything else, but the forum link in the FAQ on F22 valve adjustment is dead.
oguruma
Feb 10, 2015 06:24 PM
jdm_racer831
Apr 4, 2007 08:49 PM
