Blox Intake Mani
I have a 96 integra gsr, i installed a blox intake manifold with a hondata intake manifold gasket, I am throwing a code 92. Sometimes the check engine light will just go off for a bit, then a week later it will come back on and it is a daily driver. I know i have to get a chipped ecu and obd1 jumper harness. Do I have to put a obd1 evap purge solenoid on? Has anyone had this problem can i get rid of the check engine light to plug in with my stock p72 to pass New York State inspection?
Cool Cool Island Breezes. BOY-EE
Did you plumb the EVAP back into the manifold? You have to get a T junction and hook the PCV and EVAP back into the manifold at the large nipple in the middle of the manifold.
If the EVAP is just purging to atmosphere, the CEL will come on when it vents.
get a JDM TB or use a T to hook this and the pcv togeather
CountDracura
Mar 24, 2009 12:56 PM
