Private Label Mfg B-Series Headers: Small Tube, Big Tube, RMF Drag Style
Private Label MFG B-series ( small tube ) Tri-Y header features true step-up exhaust header technology. The Tri-Y header delivers Low-to Mid end power while utilizing a 2 piece design. This header is a Long tube design and will eliminate your Catalytic converter (CAT) and is ideal for all forms of competition, EX.. Autocross, Drag, and Road racing
Recommended for 1.6L-1.9L engine displacement
NOW GET 10% OFF EVERYTHING ON THE WEBSITE AND FREE SHIPPING within lower 48 US STATES! Use Coupon code at check out: 10BL
www.privatelabelmfg.com
PLM B-Series Small Tube Header
Basic Information
- 304 stainless steel
- Hand TIG weld
- CNC machined flange
- High flow true 2.5" merge collector
- 4 to 2 to 1 design
- Long tube
Payment Information
$325 SHIPPED to the lower 48 states
I will match ANY competitor's advertised price!!!
Got question(s) you can PM me or email me directly : BlackVelvetRS@gmail.com
Basic Information
- Hand TIG weld
- Long tube
Payment Information
Private Label MFG B-series ( big tube ) Tri-Y header features true step-up exhaust header technology. The Tri-Y header delivers Low-to Mid end power while utilizing a 2 piece design. This header is a Long tube design and eliminates your catalytic converter (CAT) and is ideal for all forms of competition like Autocross, Drag-racing , and Road racing.
Recommended for high compression 1.8L and 2.0L+ engine displacement
PLM B-Series Big Tube Header
Basic Information
- 304 Stainless Steel
- Long tube Tri-Y design
- True 2.5" Collector
- Machined CNC manifold flange
- Flange is .38" which is about 3/8" thick
The Spec's
- Primary is 44.5 mm
- Then stepped into 48 mm
- 4 to 2 Tri-Y is 50.8 mm
- 2 to 1 Tri-Y is 54 mm
- Then the collector is 65mm (which is 2.5")
Payment Information
$380 SHIPPED to the lower 48 states
Basic Information
The Spec's
Payment Information
Ignore the price above! New price $300 shipped!
Private Label MFG Power Driven ( RMF drag style ) B-series header features a true 4-1 merge , for more equal exhaust flow, this header delivers the best peak horsepower gains while utilizing a 2 piece design. This header can be installed utilizing your stock OEM Catalytic converter (CAT), but it is recommended that you use it with our test pipes to have the best potential gains.
Recommended for 1.6L-2.0L engine displacement
PLM B-Series RMF Power Driven Drag Style Header
Basic Information
- 304 Stainless steel in 18 gauge thickness
- High flow 2.5" merge collector
- 4 to 1 tubing design
- Made in 2-piece design for easy installation
- Excellent ground clearance
- It will fit w/ Air Conditioning (A/C) & Power Steering (P/S)
* Comes with FREE header gasket *
Payment Information
$300 SHIPPED to the lower 48 states
Basic Information
Payment Information
