anyone runnin' a b16 with Nitrous?
Old Aug 6, 2002 | 06:55 AM
MikeMAN's Avatar
Default anyone runnin' a b16 with Nitrous?
I was just wondering what times to expect, i just got a b16 swap and getting a Skunk 2 intake mani, with larger throttle body...
any squeezed this on a b16 before? what are ur times?
thanks again,
mike
Old Aug 6, 2002 | 09:53 AM
AllMotorMadness's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (MikeMAN)
A friend currently running 120shot direct port setup on a jdm b16a motor with all bolt-ons, slicks, untuned ran a 12.9@108mph in a 93 integ.
Old Aug 6, 2002 | 10:53 AM
wuhungsixxx's Avatar
New User
Default Re: anyone runnin' a b16 with Nitrous? (AllMotorMaddness)
is your friends motor built?...if so what does he have done to it?
Old Aug 6, 2002 | 11:38 AM
Blaze45's Avatar
Brrraaaap!
Default Re: anyone runnin' a b16 with Nitrous? (wuhungsixxx)
shiiiat 120 shot is that dp or wet?
Blaze
Old Aug 6, 2002 | 01:39 PM
MikeMAN's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (Blaze45)
wowza! that is a TON of HP to add at the press of a button..its like putting in a second engine..lol
anyone with a 55-75 shot? which would be best for my STOCK b16, wet or dry?
thanks again,
mike
Old Aug 6, 2002 | 03:28 PM
h huff's Avatar
New User
2000 si with bolt ons and 65 shot. 14.08 at 99.83 mph. 2.1 60 ft. there's more there i just need to play with it some more. i'm positive it'll do a 13.8. i'm not the best driver in the world either.
Old Aug 6, 2002 | 03:29 PM
h huff's Avatar
New User
Default Re: anyone runnin' a b16 with Nitrous? (h huff)
oh by the way that is with a dry kit.
Old Aug 6, 2002 | 04:06 PM
quicktim's Avatar
New User
91 crx hf b16a1 with i/h/e and 70 shot wet bottle pressure at 1050 and lensos w/22/8/13 slicks 1.88 60' and the car weights in at 2025 with a 1/2 tank and full bottle of n20
12.61@105.8 at maple grove raceway
Old Aug 6, 2002 | 04:15 PM
MikeMAN's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (quicktim)
kewl, so would it be possible to run a high 13 with just b16a2(no boltons) and 75shot in a coupe?
thanks,
mike
p.s. which mods take the most advantage of nitrous?
Old Aug 6, 2002 | 04:27 PM
H23 Power's Avatar
slicks and a good clutch...13 might be possible
Old Aug 7, 2002 | 09:40 AM
B16a teg's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (01GSR)
not true, my friend ran a 13.8 with his b16 with a wet 75 shot on street tires in his coupe.
Old Aug 7, 2002 | 11:36 AM
MikeMAN's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (B16a teg)
thanks for all of ur input guys!! YOU GUYS KICK *** :D
love my swap BTW
thanks,
mike
Old Aug 7, 2002 | 01:55 PM
H23 Power's Avatar
with no bolt ons?
Old Aug 7, 2002 | 10:05 PM
NegativeLift's Avatar
as far as wet vs. dry:
dry is safer, better for shots 85 or smaller.
Wet is a little more dangerous (fuel/O2 mixture in the whole intake manifold), but better to tune i you want a good fuel map both on and off the nitrous.
Direct port is like wet but better distribution to all 4 cylinders. I'd say go with this for big shots, 120 and over. Spraying a 120 shot from a single fogger, wet or dry, will not deliver the same mixture to each cylinder, with #1 getting the least N20.
Old Aug 8, 2002 | 09:34 AM
MikeMAN's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (NegativeLift)
kewlness..would the zex kit be a wise investment?
thanks,
mike
Old Aug 8, 2002 | 11:19 AM
SPOON_BeIgHtEeNsEe's Avatar
i have a zex kit for sale if interested IM me...
Old Aug 8, 2002 | 10:44 PM
MikeMAN's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (SPOON_BeIgHtEeNsEe)
how hard would it be to hit 12's???
thanks,
mike
Old Aug 8, 2002 | 11:55 PM
2000_Civic_Si's Avatar
My freind in his 2000 Civic Si is running AEM CAI, DC JDM Header, 2.5" Testpipe, Apex N1 Cat Back, MSD 6A Igntion, 8.5lb Flywheel with 6 Puck clutch, and a ZEX 75 Shot (Dry).
His best time is a 13.8 @ 101mph. His 60fts are 2.7 and spraying in first. Also, no bottle heater etc. He dynos at 210whp and 153 Tq. with his air fuel ratios at a constant 10.5.1 once spraying. Tuning could net him a few more ponies. Slicks and tuning he would have a 13.3 I am sure. If you have any ?'s just PM here on http://www.H-T.com
Old Aug 9, 2002 | 12:13 AM
MikeMAN's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (2000_Civic_Si)
wowza..that is a pretty quick time...but those 60ft's are a little slow!
nice numbers tho!
thanks for the input,
mike
Old Aug 9, 2002 | 11:19 PM
We actually went to the track tonight and he ran again here is his time slip:
R/T - 1.279
60ft. - 2.341
1/8 - 9.167
1/8 MPH - 83.01
1/4 - 13.907
1/4 MPH - 101.07
The rack was all hot and shitty tonight maybe better next time. He only ran twice his first run was a 14.3 @ 105mph. And the second is above.
Old Aug 10, 2002 | 12:05 AM
Mista Bone's Avatar
D Tranny Guru
really makes my SOHC with ZEX look fast at 13.09..........1.8 sixty foot????
Yes just a stock SOHC with I/H/E and slicks
Old Aug 10, 2002 | 03:22 AM
AussieK24's Avatar
Default Re: anyone runnin' a b16 with Nitrous? (Mista Bone)
So close to a 12, Mista!!! When????
Old Aug 10, 2002 | 08:41 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: anyone runnin' a b16 with Nitrous? (b16a4me)
soon, and on a wounded motor.
Old Aug 10, 2002 | 09:14 AM
owen_the_soyboy's Avatar
on a wounded motor.
aww chit, fix dat beast, YO!
really, 12's on a d series is wicked. for you
Old Aug 11, 2002 | 01:00 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: anyone runnin' a b16 with Nitrous? (owen_the_soyboy)
fix = dropping in a used piston to replace this.........
then upping spray to 100 shot.
