d15b hydro tranny
well first off you need an actual hydraulic transmission, without that you cannot simply covert a cable tranny to a hyrdo. i would suggest looking into the d16 y8 hydraulic tranny the gears are real short and get the most out of your d15b. secondly the cable to hydraulic conversion consists of a mechanism that bolts up to your engine/tranny that uses your current cable tranny cable, to compress the hydraulic piston on the new hydraulic transmission. it is sort of a lever looking unit, they are relatively cheap look into it through hasport.com
Walterronny
May 27, 2006 04:12 PM
jdmCivic925
Sep 23, 2003 10:02 PM
