how much do you need to worry about hydrolock
Old Jan 13, 2009 | 07:43 AM
jriley60's Avatar
Default how much do you need to worry about hydrolock
how much do you need to worry about hydrolock with an aem CAI on a b16a?
Old Jan 13, 2009 | 07:45 AM
dividedas1's Avatar
Default Re: how much do you need to worry about hydrolock
as long as your wheel liners are in place and you aren't slammed to the ground you will be fine if you avoid flooded streets, rivers and lakes. i really wouldn't worry about it a ton but DEF if its raining really bad and your area is prone to flooded you might want to rethink your drive.
Old Jan 13, 2009 | 07:53 AM
jriley60's Avatar
good good. i'm lowered a little not slammed. my buddy is hooking me up with an aem CAI. He said it is 2 pieces so it could also be short ram so i guess rainy season i'll switch it up
Old Jan 13, 2009 | 08:51 AM
EL Vap133's Avatar
Yeah switching it would be good just to be safe. Or you can just avoid big puddles, not sure how bad it rains in your area.
Old Jan 13, 2009 | 09:15 AM
Radim's Avatar
You can also use the Injen Hydroshield for the filter, or the Bypass valve from AEM to help reduce the risk of Hydrolock.
Old Jan 13, 2009 | 11:26 AM
jriley60's Avatar
well by the time i put the bypass on the horse power is equal to what the short ram would be so...i'll just do that. it's not worth risking a 2600$ motor for a few horses
Old Jan 13, 2009 | 11:34 AM
sgallagher's Avatar
How do you figure the horsepower will change if you install a bypass?
Old Jan 13, 2009 | 11:42 AM
Furyof4's Avatar
You will have no problem as long you don't drive WOT through VERY deep puddles. Which is extremely stupid anyway.
Old Jan 13, 2009 | 11:54 AM
jriley60's Avatar
everything i read says it will drop 1 or 1.5 hp
Old Jan 13, 2009 | 12:30 PM
bprsk8r4272's Avatar
it wont drop alls it is is another filter which will let the water/moisture out
i have the ebay bypass valve
Old Jan 13, 2009 | 07:04 PM
~sp33~'s Avatar
EFB055
Not that 1.5 hp means anything in the real world.
Old Jan 13, 2009 | 07:21 PM
Intocable's Avatar
I've had one on my car for 4 years straight and never had a problem. My car is pretty low and sometimes I pass over small puddles. I think basically as long as your not flooring it over giant puddles or driving into one deep enough to cover it (almost did that once...couldnt even see the damn puddle)
Old Jan 13, 2009 | 08:34 PM
sgallagher's Avatar
Not that its the same but I've mobbed through a very flooded street(didn't look that flooded due to the curbs were almost 3 feet high). I was driving a 93 Toyota pickup and the engine stumbled and stalled just as I made it out of the water. Started right up and cleared out the water. I guess it was just luck though.
Old Jan 13, 2009 | 10:08 PM
hatcht9x's Avatar
okay.. so I haven't really had much experience in this area.. but I thought I would just throw this out there.. Is the intake vacuume really strong enough to pull moisture from the damp filter and up through the pipe? and even then, would that moisture not just be expelled from the motor through the combustion/exhaust? ( this is looking at it from the normal splatter of water from the road below or the tire) I totally get the big puddle and submerged pipe.. but how strong is the intake vacuume?.. feel free to school me!
-thanks, Chris
Old Jan 14, 2009 | 10:36 AM
sgallagher's Avatar
-thanks, Chris
The problem is the big puddles of water. A small amount of water isn't going to matter much. After all the ambient air even has moisture in it. But the engine will intake the easiest thing it can (air). If its only choice is water(being completly submerged) its going to give it every thing its got to pull it in.
Old Jan 14, 2009 | 10:40 AM
hatcht9x's Avatar
sgallagher.. thats what I had thought also. thanks.
Old Jan 14, 2009 | 11:16 AM
dcvt16's Avatar
lol, that **** was funny... we were like aww man!! the owner of this truck is gonna be pissed..
but to the op, ive never heard of the bypass losing powr. it doesnt really effect anything until the filter is submerged.
if you search around i think there is a vid of an nsx with the filter fully submerged while on the dyno.
bl1tzk1213g
Jun 9, 2007 05:40 PM
Red4drLSintegra
Northern California (Sales)
Nov 25, 2006 12:51 PM
[HrZn]4life
Dec 23, 2002 09:58 PM
IntegrasGoFast
Dec 4, 2002 03:38 PM
Project X
Dec 11, 2001 12:29 PM
