crx si motor
Old Jan 12, 2009 | 06:38 PM
9c0rxsi's Avatar
Default crx si motor
what other d series motor are easily swaped into the si
Old Jan 12, 2009 | 06:44 PM
wasabivtec's Avatar
Default Re: crx si motor
none that are worth while... if you want to stick with the single stick build a mini-me otherwise go B or K
Old Jan 12, 2009 | 06:48 PM
D16SiHatch's Avatar
d16z6 or d16y8. easy because they don't require you to change shift linkages, engine mounts, axles, etc. mini-me is also an option, but high mileage bottom ends tend to go out after you swap on a newer cylinder head.
Old Jan 12, 2009 | 06:54 PM
90 DX Driver's Avatar
Not sure if its the same in the CRX but im doing a ZC dohc in my hatchback in the future. heard it isnt that expensive to do and pretty ez
Old Jan 12, 2009 | 07:32 PM
ef8sleeper's Avatar
just as easy as the d16z6 or the d16y8.
a word of advise tho.
you can probably find an d16z6/y8 thats in better condition than a dohc zc for cheaper, produce the same horsepower, and not have to worry about the compexity of a dohc engine.
dohc zc's are gettine old.
i say stick with a single cam vtec since its the same horsepower than a dohc zc...
Old Jan 13, 2009 | 03:08 AM
CRX Toad's Avatar
Check the FAQ, that is going to be the best way for YOU to research what motor YOU want to put in YOUR car.
grncivic91
10
Jul 23, 2013 10:02 AM
BlueRex1020
17
Jul 16, 2006 12:37 PM
hatchvtec
22
Oct 28, 2005 06:23 AM
bluebluecivic
Jan 21, 2005 07:02 AM
PatEJ6
Mar 20, 2002 06:20 AM
