what socket size for oil pressure swith
Old Jan 12, 2009 | 12:51 PM
maxogsr's Avatar
Default what socket size for oil pressure swith
I'm trying to unsrew my oil pressure switch behing my block for a oil pressure gauge install... what socket size do I need to take that swith off there? I try searching but could not find the answer...
Thanks!
Old Jan 12, 2009 | 01:04 PM
EFsSuck's Avatar
Default Re: what socket size for...
24mm deep 6-point socket.
Old Jan 12, 2009 | 01:21 PM
sheekdude's Avatar
Just buy a honda sensor tool... its much easier to use, but the socket will also work fine.
Old Jan 13, 2009 | 10:17 AM
Mashimaro's Avatar
Default Re: what socket size for oil pressure swith
didn't want to run a sandwich adapter?
Old Jan 13, 2009 | 10:21 AM
maxogsr's Avatar
sandwich adapter? I want a "tee" male the size of the pressure switch, one female end the same size and one female 1/8 npt...
Old Jan 13, 2009 | 11:45 AM
Mashimaro's Avatar
This is the sandwich adapter i'm using with my gauges:
Oil pressure and oil temp plugs into it.
Just a suggestion of course
Old Jan 13, 2009 | 12:25 PM
maxogsr's Avatar
It's not a bad idea... what brand is this one? Easy to use? No leak? What are the port size?
Old Jan 13, 2009 | 12:45 PM
Mashimaro's Avatar
Brand is Al-Fit (distributed by Tein USA) but i'm sure you can find other alternatives out there as well (Golden Eagle i think?). Port sizes are written on the package,they work on my Defi gauges for Oil temp and oil pressure (used the 2 smaller holes, not the big brass plug one). hope that helps!
Old Jan 14, 2009 | 06:30 AM
maxogsr's Avatar
24mm long was finally the right one... shame on me!
RedPinoySi
Jun 12, 2007 05:23 PM
DrivinVtec
May 29, 2006 05:49 PM
ITR3189
Jul 27, 2005 11:02 AM
g2_boosted
Oct 13, 2004 10:52 PM
92sleepR
Oct 4, 2001 05:08 PM
