Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
steering wheel is locked after starting car
Old Jan 12, 2009 | 12:26 PM
MUGEN_EG95's Avatar
Default steering wheel is locked after starting car
Got an 07 honda civic SI....when i try to turn the key its really stiff..it starts but after that the steering wheel is locked. What could be wrong???
Old Jan 12, 2009 | 12:29 PM
knaira112387's Avatar
Default Re: steering wheel is locked after starting car
user error.
-end-
Old Jan 13, 2009 | 12:35 PM
ken9's Avatar
Hi! I had this problem before. Did you turn the steering to the left or something? Can you push the brake down too?
Old Jan 13, 2009 | 02:20 PM
FijiBlueFG2's Avatar
Road House
Not sure about the SIs, haven't experienced it yet. On my EM2 there was some trick where you pushed the brake pedal and turned the key.
My guess is you park on a hill? Put the E-Brake on.
Old Jan 13, 2009 | 06:57 PM
COCA GROUND ASSAULT NY's Avatar
I had a problem last week when it was really cold.. When i started my car i tryed to pull off and steering wheel was very stiff (like power steering wasnt working)..i turned the car immediately off and restarted it , then it was fine.. When i took the car to the dealer the other day i asked one of the mechanics he told me could have just been because of the cold , power steering pump must have froze.. I guess when i restarted the car it must have reset ..
Old Jan 13, 2009 | 09:33 PM
07galaxygrey4dr's Avatar
this is no bs. i have an 07 si, and have experienced this numerous times. most recently, 2 days ago. if you turn it off and crank it right back up, it will usually work fine. sometimes, it has taken cranking the car 3 times. never more. it's still a pain, when you are in a hurry.
Old Jan 14, 2009 | 12:24 PM
.. thats what i was talkin about probably the steering pump be freezin so it just needs to be reset.. and by re starting the car ir does just that
Old Jan 15, 2009 | 09:01 AM
MUGEN_EG95's Avatar
the car is working fine now...when it first happened i noticed the steering wheel light came on. so i thought it was low on power steering fluid but i looked everywhere and couldn't find it. I read the car manual and it said the SI doesn't come with power steering reservoir. I did some more searching on 8th gen civic forums and people there have the same problems also. A few people took their SI to the Honda dealerships but they couldn't do anything....so now i'm bummed!
Eee Kayyy
Apr 16, 2019 09:58 PM
Ur 2 Slow 4 J
Nov 1, 2015 02:25 PM
n00b
Jun 7, 2005 04:55 PM
