Disabling VSS?
Old Jan 12, 2009 | 11:31 AM
dpine's Avatar
Default Disabling VSS?
Can you (when using a shipped ecu) disable VSS on an obd1 ecu?
Old Jan 13, 2009 | 04:35 PM
HamiltonRex's Avatar
Default Re: Disabling VSS?
Why would you want to do that?
You can however remove the speed limiter if thats what you wish to do.
Eric.
hybridmath's Avatar
why woud you wanna do that if i may ask ???
Old Jan 13, 2009 | 04:36 PM
hybridmath's Avatar
if you are tring to get vtec to work with a obd0 car/cable speedo just set vtec to 0mph
Old Jan 13, 2009 | 06:41 PM
dpine's Avatar
Bingo. I may be going to install a obd1 motor/ecu in to a 87 crx. I wanted to use a obd1 ecu for better tuning options.
hybridmiklo
Mar 7, 2009 08:12 PM
pentsas
Dec 2, 2008 12:53 PM
ej8
Oct 29, 2006 10:46 AM
dkrex001
Oct 25, 2006 02:09 PM
