93 civic hb turbo?
i HAVE A 1993 CIVIC HB WITH A D15B7 AND AM PUTTING IN A D16Z6 USING A CX EXHAUST MANIFOLD! PEOPLE ARE TELLING ME I CAN USE A ECLIPSE FACTORY TURBO?? WHAT YEARS CAN I GET A TURBO OFF??LOOKING FOR 8-10LBS!
STOP TYPING EVERYTHING IN CAPITOL LETTERS LIKE THIS, ITS ANNOYING.
Why are you using a CX exhaust manifold? You do realize that you'd have to cut and try and weld a flange onto it to use the turbo right? Yes, you can use a factory Eclipse turbo from 90-99.
You need to do some searching and if you want forced induction answers, go to the forced induction section.
ok so this site wont let me see forced induction pages! what will i need besides tubing and intercooler and bov and oil line is there anything else?
no need for caps. Instead of PSI goals, try determining whp goals. The way PSI generates horsepower varies depending on the turbine used. Then you will be able to find out what needs to be done to make such whp on your engine, reliably.
4rcefeddeceiver
Dec 11, 2003 06:18 PM
DroppedIntegra
Jun 20, 2002 11:17 AM
