going 80 mph in 5th gear at 3.5k rpm?
Old Jan 12, 2009 | 06:58 AM
down_the_hatch's Avatar
Default going 80 mph in 5th gear at 3.5k rpm?
does anyone know what transmission this most likely is? I bought it from someone and he said it was a GSR. It says Y80 on it.
Old Jan 12, 2009 | 07:16 AM
Schister66's Avatar
Man U FTW
Default Re: going 80 mph in 5th gear at 3.5k rpm?
My GSR does 4k at 80mph. Not sure that helps, but there's a big difference in the gearing from 3.5k to 4k at the same speed. What size tires are you running?? I have different rims than were stock on my GSR, but i kept the overall diameter the same; therefore, the gearing should be almost identical to stock.
If i had to guess, you have an LS tranny or an LS final drive in a GSR tranny...
Old Jan 12, 2009 | 07:35 AM
its an ls motor in my eg hatch with 15" wheels. i really hope its not an ls trans. paid $550 for it and it grinds 2nd and 3rd!
Old Jan 12, 2009 | 07:40 AM
lazii_boi08's Avatar
u payed that much for the tranny and grinds???
Old Jan 12, 2009 | 08:05 AM
sure did. i was told that it had low miles and everything was coo on it. so i called dude back and told him wus up and he said i need gsr shift linkage. im running ls shift linkage right now. he was full of shyt
Old Jan 12, 2009 | 08:27 AM
p28yaj's Avatar
You bought a ls tranny. The gsr/ls shift linkage are the same for eg/dc chasis. oh and by the way ls final drive is the same as the gsr.
Old Jan 12, 2009 | 08:43 AM
mouab18c1's Avatar
dont gsr trannys have s80 on it? or is it y80?
Old Jan 12, 2009 | 08:56 AM
hatchling37's Avatar
Doubt it's a GS-R, unless it's got some weird final drive and fifth gear. I'm at about 3000 rpm at about 60 mph with my LS with GS-R tranny.
Old Jan 12, 2009 | 09:55 AM
TOO MUCH TORQUE's Avatar
i have an 01 LS. it spins at ~3.5k rpms @ 80 mphs. 3k @ 70 mph....
Old Jan 12, 2009 | 10:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
BINGO - OP has an LS tranny for sure.
GS-R tranny goes like this in 5th gear:
2000 rpm = 40 mph
2500 rpm = 50 mph
3000 rpm = 60 mph
3500 rpm = 70 mph
4000 rpm = 80 mph (all speeds approximate of course)
Oh, and tire size has ZERO effect on what the guage cluster reports as speed vs. RPM. Speed is read as a function of the differential's rpm, so speed will always be the same at a given RPM given the same speed sensor gear on the diffy. Whether or not that reported speed is accurate is another story altogether.
Old Jan 12, 2009 | 10:21 AM
kulo's Avatar
SB9 tranny is the same as gsr tranny?
its from the ukdm b18c4 sb9 tranny with LSD
Old Jan 12, 2009 | 11:41 AM
pmey's Avatar
it's both
Old Jan 13, 2009 | 07:04 AM
man am i pissed!
Old Jan 13, 2009 | 10:21 AM
JReal's Avatar
wuttt
Old Jan 13, 2009 | 10:45 AM
mouab18c1's Avatar
man am i pissed!
hustle his ***!
Old Jan 13, 2009 | 11:15 AM
CompanyFlow's Avatar
Is it possible he has an LS 5th?
Old Jan 13, 2009 | 11:26 AM
pmey's Avatar
if you drove both gsr and ls you should know the difference in 3rd and 4th gear between them two
Old Jan 13, 2009 | 11:40 AM
vietnamezerice's Avatar
i was scammed recently... i know how you feel man
Old Jan 13, 2009 | 02:11 PM
HB1320's Avatar
im almost sure its an LS my motor is the same thing
Old Jan 13, 2009 | 02:18 PM
vladd's Avatar
it is. people have put ls 5th gear in gsr trannies before. the op should test other gears and post them on here.
Old Jan 13, 2009 | 03:23 PM
slammedeewagon's Avatar
Haha my trans is like 3200 at 60 I heart my gsr but its to short for dd driving
Old Jan 13, 2009 | 03:26 PM
bunnyhatch93's Avatar
Deffinatly a LS tranny. I had a GSR tranny in my eg hatch and it was at around 3500 at 70-75 mph.
Old Jan 13, 2009 | 03:53 PM
majinsoftware's Avatar
Must be nice with long 5th gears. Mine at 100ks (62mph) 4200rpm in 5th. 4.9FD .
I would defently get in contact with that guy and get your money back, If he refuses get in contact with police. Iv been scammed with a transmission and It really sucks but I left it too long to be able to get my money back.
Old Jan 13, 2009 | 04:50 PM
thats the thing. i dont have his number anymore and i forgot where he lives. i started a post asking if anyone would know this guy. and its been over 2 months easily.
Old Jan 14, 2009 | 05:57 AM
pmey's Avatar
I just had a GSR Y80 tranny put in b20V teg and at 60mph = 3k
and my other LS at 60mph = 2.6k
