DC5R S2 Mega Power Exhaust
Old Jan 11, 2009 | 07:54 PM
lightningfield's Avatar
Default DC5R S2 Mega Power Exhaust
guys my DC5 type r will be out soon. wanna ask wether it is worth to equip my car with the 3inch S2 mega power system, or shall i just stick to apexi N1 with 2.3inch. the engine is relatively stock with open pod air filter set and pre-tuned emanage ultimate + vmanage.
appreciate if you guys can also post d pics of the S2 exhaust on a RSXs..
thanks.
Old Jan 11, 2009 | 07:56 PM
Jdc5's Avatar
Default Re: DC5R S2 Mega Power Exhaust
bigger exhaust means bigger power. i say skunk2. its up to you tho
Old Jan 11, 2009 | 08:03 PM
thats what i have in mind. someone is selling the S2 dirt cheap, and it looks way nicer than apexi LOL.
Old Jan 11, 2009 | 09:33 PM
DaveSi677's Avatar
this is false!!!
Bigger exhaust can make you gain or loose power... it all depends on the application!!!
A N/A car will loose power with a 3'' exhaust but a turbo'ed car will make more power with a 3'' exhaust then a 2.5''... its having the right amount of back pressure!
Old Jan 11, 2009 | 10:25 PM
DcLs's Avatar
Originally Posted by DaveSi677
this is false!!!
yup he's right
Old Jan 11, 2009 | 11:28 PM
NTCustoms's Avatar
davesi is correct. bigger exhaust doesn't equal bigger power. for your current mods i'd stick with the 2.3"
Old Jan 12, 2009 | 01:03 AM
hawaiiancb74's Avatar
this is false!!!
my na car oddly gained power at 3inches.. weird.... not weird at na people use 3 inch all the time and make great numbers.
Old Jan 12, 2009 | 01:04 AM
Paul-R's Avatar
Bigger means more if you get the right suitable for the mods that are on your car .
your mods dont really scream hey i need three inch tho, not worth the loudness. but im pery sure you car will gain something even if you put the 3 inch on.
Old Jan 12, 2009 | 01:05 AM
its a kseries engine bigger always means more in this case.
Old Jan 12, 2009 | 05:16 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
this is false!!!
you are false,plenty of dyno proven charts on CRSX that prove the k series loves the 3" exhaust. A B series n/a would loose power yes.
http://forums.clubrsx.com/showthread...ghlight=3+Inch
But for the TS if you dont plan on doin i/rh/tune and any other mods kinda overkill but awesome!
Old Jan 13, 2009 | 09:41 AM
Jdc5's Avatar
this is false!!!
Your thinking like these k's are like the b's. These are engines built to breath alot. Skunk2 built these for reason for the k's and differently for the b's. Yeah alot of back pressure is lost when using it on a b series na but with a transverse engine the exhaust exits quik making back pressure over rated for the k's.
Old Jan 13, 2009 | 11:55 AM
DaveSi677's Avatar
I took a look and I was impressed the only thing is that he mentions that his line goes from a 2.5'' to a 3".... so its not a full 3" line althought that being said I believe that probably the way the K was designed it might need the extra .5'' to be able to make maximum power.
I am going to research this a little more looking for other dyno graph as I cannot fully believe this after just seeing one chart... but I can't say that I am completly right! So basically I will get back to you on this lol...
Btw good find Type-'S'paz
Old Jan 13, 2009 | 12:45 PM
umm well ive had multiple customers make great numbers while using a 3 inch, most of which have used a smaller exhaust. i went from a 2.36 to a 3 inch and opened up about another 12 hp on th tune an about 8tq
Old Jan 15, 2009 | 04:15 PM
appreciate your response guys.
i might just buy and keep it for future use.
any pics of RSXs with the exhaust?
Old Jan 15, 2009 | 04:43 PM
DcLs's Avatar
here you go mang http://forums.clubrsx.com/showthread.php?t=204378
Old Jan 15, 2009 | 05:16 PM
DcLs,
thanks a lot man.
i shall post my pics soon!
darkvader0
Jan 22, 2010 04:26 PM
mrdeadman
Jul 17, 2005 10:57 AM
civicky
Aug 12, 2003 12:17 PM
