Detailing Auto Detailing and Concours
Presidential Detailed: 2004 AC COBRA 427ci
Old Jan 11, 2009 | 06:31 PM
Presidential_Detail's Avatar
Detailing Mastermind
Default Presidential Detailed: 2004 AC COBRA 427ci
This car was brought to me by S&R Performance here in Tampa, FL. In the end we decided upon a "basic" exterior, 1-stage polish just bring back the luster but not really remove any defect beyond what my polish would do. We also did an interior detail, which I forgot to take afters of and we are scheduled to do the engine compartment in a couple weeks. The owner came by to check on the car and was very satisfied with the results and we may even be doing a full blown "Presidential" Exterior to this car in a couple months. We also scheduled his Audi S8 while he was there!
First off before we get started, this car was built in AFRICA!!! I must say it is one of the best aftermarket paint jobs I have probably ever seen. There were litterally no flaws in the paint job itself. The flaws I did happen to find were a few spots where it seemed after wet sanding, the body shop did not fully remove all of the scratched from the sand paper. The car also had quite a bit of swirling in it, but it probably hadnt even been washes since it was built! Even though the customer was satisfied with how the car looked, I pointed out the problem areas and he was interested enough to eventually reschedule the car for the full polish job. ENJOY!!! I DID! :D
Products:
Exterior:
Optimum No Rinse
ONR diluted to clay lube
COBRA UMF Wash Mitt
COBRA Deluxe "Jr" MF's
Dual Buckets with Grit Guards
3m Masking Tape
Adams Professional Clay Bar
Meguairs APC+
Meguairs Hyperdressing
Menzerna IP/White
91% Isopropyl Alcohol
Tons of Uber MF Towels(AP)
Swissvax Pneu
LSP:
P21S "100%" Paste Wax applied with Uber Foam Applicator
Tools:
Dual Work Lamps
Makita Hi Speed Rotary
World's Greatest Boar's Hair Wheel Brush
Foam Pad Cleaning Brush
DD Detail Sponge
The Wheel Well/Fender Brush
The Spoke Brush
Canon Rebel XTi
Craftsmen 295MPH Vac/Blow
E-Z Detail Wheel Brush
Swissvax Wheel Brush
BEFORE:
Old Jan 11, 2009 | 06:32 PM
Default Re: Presidential Detailed: 2004 AC COBRA 427ci
The car looked great already, but I knew that wouldnt be the case in the sun!
As you can see there were also some buffer trails, I have a feeling they rushed the car out after paint/wetsanding and didnt do a thorough job of polishing the car.
I played around with a few polish/pads to find out what would give me good correction abilities while also finishing down LSP ready...I tried optimum polish on a white pad, it did not cut very well and was still too harsh to finish down lsp ready. I then tried Menzerna IP on a white pad, since I have had good results with SIP/White(I ran out of SIP)and it was my choice for today also!
50/50..As you can see it cut down the swirling quite a bit and also left a LSP ready finish.
Even inside, you could tell the finish was significantly deeper than before..
Old Jan 11, 2009 | 06:33 PM
I was limited on time with this car, so I didnt get as many detailed pictures as Id like..but here are some afters!
Some more..
Old Jan 11, 2009 | 08:02 PM
1.5Slowmatic's Avatar
INSANE. My fav. car of all time right here, well the real one anyway
Old Jan 13, 2009 | 01:39 PM
XpLiZiT's Avatar
i spy a ruckus...
fantastic work btw.
oh and a quick question... what do you suggest for cleaning the tires? everything ive used up to date has just been mediocre at best
Old Jan 26, 2009 | 01:59 PM
Originally Posted by XpLiZiT
i spy a ruckus...
fantastic work btw.
A ruckus is indeed in the shot! As for tires I generally use Meguairs APC+ Cleaner with a strong dilution. For tires with whitewalls, Ive always had good luck with Blechewhite Tire Cleaner, you can find this at most autoparts stores.
Old Jan 26, 2009 | 06:16 PM
dc4_wHORE's Avatar
Soldering Iron Wizardry
i wish i could make a car look like that.. good job
Old Jan 27, 2009 | 08:21 AM
LightningTeg's Avatar
Community Builder
Im new to detailing here, but do you give the cars a final wash after your done polishing and waxing? Or just a rinse? Thanks
Old Jan 27, 2009 | 06:00 PM
Sometimes I will wash them, but definitely always atleast rinse. I usually wait until AFTER waxing, to ensure I do not wax water spots back into the paint work!
Old Jan 27, 2009 | 09:53 PM
RedRCKT000's Avatar
what products do you use to get that deep finish?
Old Jan 28, 2009 | 09:23 AM
I only performed a 1-step polish on this car using Menzerna IP/White pad, along with a combination of the products below. It was waxed with P21S 100%.
Products:
Exterior:
Optimum No Rinse
COBRA UMF Wash Mitt
3m Masking Tape
Meguairs APC+
Menzerna IP/White
Swissvax Pneu
LSP:
Old Jan 28, 2009 | 09:56 PM
RedRCKT000's Avatar
Wow I figured you used like Zaino bro's or something like that to get that shine not some Meguairs thats crazy.
Old Feb 2, 2009 | 07:58 AM
I didnt use Meguairs polish, I used Menzerna. Zaino is good for the average consumer, but doesnt stand up to a pro level detail.
thisguyaves
Paint and Body
Aug 3, 2018 01:39 PM
ali7o3
Paint and Body
Feb 21, 2010 11:04 AM
theehibachi
Paint and Body
Aug 30, 2009 09:40 PM
zerovandez
Paint and Body
Feb 5, 2009 07:11 PM
